03 lb7 power and fuel problems
Old Feb 10, 2013 | 06:32 PM
chevyduramax1's Avatar
Default 03 lb7 power and fuel problems
I have 03 lb7 in a 3500 dually on the way home about mile from home fuel gauge went to 0 and fuel light came on and it lost all power it would rive at about 15 mls per hour I changed the fuel filter but it didn't help any . the filter was only half full of fuel so it it is not getting fuel I think someone told me it was a lift pump oriely's said it was inline sold me one but I have dropped the tank and followed the fuel lines all the way to the engine and not found a lift pump Help how do i pull codes with out taking it to dealership or plugging in anything ?? any ideas what this could be .. oh when moving some of the wires the fuel gauge came back up worked for few min.. it has 3/4 tank of fuel ...yes I know it was heavy to drop down but i put it back up now any ideas
Old Feb 10, 2013 | 10:36 PM
97cummins's Avatar
It sounds like you may have a bad sending unit in your fuel tank, that may be sending a false signal to your ecm telling it to put the motor into a limp mode.But also you said when you moved some wires the fuel gauge started working, that sounds like a connection problem. And does your dash have a digital read out?
Old Feb 19, 2013 | 02:38 PM
perkinsd_theone's Avatar
I'm with you 97...... sending unit.
Back-in-Black
8
Aug 13, 2017 10:35 PM
Dbleo351
Nov 20, 2016 09:34 AM
J. Nick
Apr 24, 2015 01:13 PM
robbyS
Apr 16, 2015 02:22 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
