07.5 Smarty & Delete problems..
Old Feb 7, 2013 | 12:50 PM
1st_gen_puller's Avatar
Default 07.5 Smarty & Delete problems..
I have a smarty set on level 7 with full deletes and i still get CEL with 3 codes one is unknown code, 1 is something like turbocharger boost sensor voltage high, and 1 is like EGR temp sensor too high/ or high voltage. Sorry i cant remember the exact codes.. also my overhead periodically shows catalyst full service reqd.. and it is a dog now almost like limp mode... i dont get it.. runs normal till it starts to boost up seems like.. kinda either boost or rpm relevant you know.. thanks for any help please...
Old Feb 7, 2013 | 06:48 PM
coors_man_2005's Avatar
are you running an me file?
Old Feb 7, 2013 | 06:54 PM
No idea.. straight putta the box..
Turbo just took a dump on me... guessing that was the problem..
Old Feb 7, 2013 | 07:41 PM
Well look at the numbers when u first plug the smarty in at the end should say me if not let me know and ill send you some files cause u have to run the me files and with the codes your throwing sounds like your prolly running the wrong tuning that might have helped cause your turbo to crap out
Old Feb 7, 2013 | 08:25 PM
Ok what is a ME file exactly??
Old Feb 7, 2013 | 08:38 PM
Middle East off road tune. Deletes the DPF
Luke
Old Feb 7, 2013 | 09:32 PM
It deletes all the emissions egr dpf all that good stuff
Old Feb 8, 2013 | 04:27 PM
Well my guy ''says'' it has that but were gonna update it.. thanks guys..
Old Feb 8, 2013 | 11:52 PM
dont sound like it with the codes your throwing
Old Feb 9, 2013 | 08:19 AM
ya.. also should i upgrade turbos or just stay with the stock??no ex brake so that doesnt make a difference.
