HT3B rebuild?
Old Jan 31, 2013 | 08:27 PM
Rusty89Cummins's Avatar
Default HT3B rebuild?
what does it take to rebuild a ht3b turbo? is it pretty straight forward just dissassemble, clean, and replace new parts with old? or is some tricks for anything, anything to watch out for, sertain torque specs and such? ive never rebuilt a turbo. thanks for any help.
Old Jan 31, 2013 | 08:34 PM
RAW's Avatar
RAW
I did my HX35 and S471 this spring. Pretty much like you said, take apart, clean, replace, assemble.
Lay everything out in order so you know how it goes back in. Look twice before reefing on anything. Take your time. It will go well.
Old Jan 31, 2013 | 09:06 PM
hmm alright. ill probly look up a diagram breakdown and i think ill be ok.
Old Feb 2, 2013 | 11:57 AM
blackduck's Avatar
A manual would be first on the shopping list.
Little tricks like is shaft matched marked to the impeller, match mark housings.
Left hand threads?
DO NOT side load the nut or shaft when taking apart or installing the impeller nut. Using a TEE bar may help prevent side oadling when stripping apart, just care when torquing up,
Keep bearing area and shaft CLEAN.
Lube well before firing up.
Torque to specs
Have fun
No3l
Oct 20, 2015 07:21 PM
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
davidthomas
Mar 24, 2015 12:41 AM
twm011
Feb 24, 2015 09:11 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
