Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
04.5 lly
Old Jan 31, 2013 | 09:11 PM
markit04's Avatar
Default 04.5 lly
Ok, third post. After 3 very frustrating days, I realized I did the return check wrong. I checked flow out the return to the tank, so it was total return fuel (about 160ml/15sec.) So I was about to test return flow from each bank of injectors. I say about too because after 2 days of NO DTC's all of a sudden I get a P0090 code for fuel pressure regulator. At this point I'm not sure what to do, certainly don't want to be a parts swapper, but I'm not sure where to go next. To begin with I'm going to clear the code, do a batt disconnect and start the DTC process over. If anyone should have opinions I would love to hear them. I will follow up with what I find.
Thanks
Here is the current info I have received on this situation. It comes straight from the GM people. Apparently if a P0090 code (fuel pres, reg.) exists with a no start situation the ECM needs to be replaced. Has anyone else had this problem? Any GM techs want to chime in here? I get NO other codes.
HighVoltageHero
Apr 23, 2015 10:54 PM
JordanR
Feb 28, 2015 03:24 PM
SMCCARY
Diesel Engine Conversions
Jan 23, 2015 02:16 PM
JordanR
Dec 26, 2014 06:17 PM
duramaxtuner
04.5-05 LLY Performance
Dec 10, 2014 01:56 PM
