06 injectors
Old Jan 30, 2013 | 05:59 PM
cody at sunny slope's Avatar
Default 06 injectors
hi, i am looking for a new set of injectors for my 2006 2500 megacab. the vehicle has stock tuning and no power adders. i do however have a built transmission. the truck has 150000 miles and a bad injector. rather than just replacing one injector i want to do all of them. i dont have any short term plans of installing any power adders. I was however thinking about going slightly over stock with the injectors (50hp max). My question is what brand of injectors should i go with and where should i buy them? I dont want a cheap made injector with large variances between the six. What is a good company that does flow test and correct all of their injectors?
any help would be greatly appreciated
Old Jan 30, 2013 | 10:12 PM
BigSilverBullet's Avatar
Industrial, I think BD makes some, but sure there are a lot more guys on here that will answer that question better!
Old Jan 31, 2013 | 07:31 AM
steved's Avatar
I had Flux Is (+40HP) in my truck for well over 130k miles without any issues...the last 80k of that was with a SmartyJR.
Old Jan 31, 2013 | 09:23 AM
dangerous1965's Avatar
Want to do it right! Check these out: Heads Up on BBI Injectors! - Competition Diesel.Com - Bringing The BEST Together
And do NOT forget to install a 2 micron filter before the CP3!
Old Feb 4, 2013 | 05:52 PM
jkidd's Avatar
Industrial make sure they are all closer than bosch spec. Good value.
Old Feb 4, 2013 | 06:03 PM
Farmboy 2.0's Avatar
Just a set of bosch 275 injectors. Those are 40hp gains
Old Feb 9, 2013 | 11:48 PM
Rainman44's Avatar
If you have no plans of short term mods and you plan on using all of your right foot and or haul anything go stock sticks. Bigger ones even if only 40hp will drain the rail causing high egts and the 5.9 HO are known for burning up number 6 piston. Best advice is if your gonna give her more fuel you have to give her more air period.
Old Feb 10, 2013 | 09:39 AM
steved's Avatar
I've been on the diesel forums for over 10 years now, and never heard such dribble.
Old Feb 10, 2013 | 09:53 AM
Rainman44's Avatar
This trucks only been out 7 years bud. Diesels are more precise than gas your talking 26-28000 psi of rail pressure and 600 lbs of compression per cylinder. You put the balance off your gonna have problems could last a week or 10 years
Old Feb 10, 2013 | 10:09 AM
steved's Avatar
Ummm, seven years? They intro'd the CRD 5.9 in 03...any good troll could research that.
I find it funny how you're the first to ever talk about low HP sticks causing any issue. I put no less than 272k on my last truck running a set of 40hp sticks for the last 120k. Same engine, never a mechanical issue (except the original injectors). As I stated, I've been on these forums for over ten years, and you're the first...
Have a nice day...
