Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
04 lly no start
Old Jan 29, 2013 | 06:24 PM
markit04's Avatar
Default 04 lly no start
I'm adding to my initial post. Truck won't start (cranks fine) no DTC's no air in fuel. have'nt checked rail pressure (my scanner won't). I have approx. 150 ml of fuel return cranking. Is it possible pres. relief valve is stuck or fuel pres. regulator is causing this problem? It started fine over the weekend but I had to use the priming pump the first time Sat. and again on Sun. then it was fine. Shut it down Sun. afternoon would not start on Mon. I messed with a bunch of stuff and it started yesterday, ran good,restarted immediately after shutdown but would not start again this am. I checked fuel return rate and it was about 150ml while cranking (15 sec.) If the pressure reg sticks would I get a high return rate?
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
