before start, fresh rebuild
Old Jan 28, 2013 | 10:11 AM
helton87's Avatar
Default before start, fresh rebuild
im rebuilding my 03 5.9 and going to be putting it back in the truck in a few weeks. my question is how can i prime the oil system before startup? or is the assembly lube going to be good enough untill it receives oil pressure? thank you in advance!
Old Jan 28, 2013 | 12:48 PM
TheOtherNick's Avatar
Pull the lift pump fuse and crank it for 15 sec like 3 times
Old Jan 28, 2013 | 01:23 PM
helton87's Avatar
i was thinking about that or just leaving the valve cover off, putting the oil in accrost all of the top of the head and hold off on plugging in the injectors and cranking until i see oil come up through the pushrods (crank for 15 sec then letting it set for a few to keep from burning up the starter and place a box fan on the floor aimed at the starter for a constant air flow to help in keeping it cool.)
Cavnar
Sep 9, 2015 07:18 PM
Hmfman91
8
Jul 3, 2015 05:52 PM
cjgregory
Mar 31, 2015 01:45 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
