DieselBombers Truck Of The Month Truck of the month done DieselBombers style
View Poll Results: Which conversion truck gets your vote?
cummins broncos 1978 Ford Bronco
30.51%
redneckMANAICs 2004 Ford F250 12 valve
6.78%
Paintballrepins GMC/2500/RCLB w/DMax
22.03%
Uncle_jesses 93 f350 4x4 w/12 valve
20.34%
angelic0-s Dodge RAM 1500 w/12 Valve
10.17%
2005Fummins 2004 Ford F-250 Lariat w/24 valve
10.17%
Voters: 59. You may not vote on this poll
Febuary TOTM Voting
Old Jan 5, 2013 | 07:00 PM
cummins bronco's Avatar
lets try again!!
Originally Posted by Mdub707
[SIZE=5]Ok everyone, here we go again.
Truck of the Month Entry Form
Owner name: Sam Burton
Forum username:Cummins Bronco
Hometown:Armstrong BC Canada
Make/Model/cab and bed configuration: 1978 Ford Bronco
Engine mods –
Engine: 5.9 12V Cummins
Tuning: screwdriver, DennyT fuel pin, 3200 gov. spring
Injectors:stock
Turbo:HY35
Intake:custom
Exhaust:custom 4" with Magnaflow muffler
Fuel System: modified stock
Other: BD exhaust brake, powerstroke intercooler
Transmission mods –
Auto/manual:ZF5 stick
Clutch/Torque Converter: LUK Gold
Other:NP205 transfercase
Exterior –
Suspension:old 4" susension lift, custom traction bars, shackle flip in rear
Wheels:16x10 Ions
Tires:315/75/16 Toyo Open Country M/Ts
Other:3/4 ton diffs, locked front
Interior –
Audio upgrades:Kenwood Exelcion head unit, custom sub box/console with 10" Alpine competion sub with Hertz 800watt amp, 2 pairs of 6 1/2s in custom mounts
Creature Comforts: convertible!
Other:
Miscellaneous:
daily driver, tow rig, cross country cruiser, off road toy, this thing does it all!!!
Favorite Mod:
the Cummins of course!!!
and some new pics
figured you guys might like some action shots!
this was right after i got it done
just cause i am proud of my dragstrip experience
and an engine shot
Old Jan 10, 2013 | 07:24 AM
redneckMANIAC's Avatar
Owner name: Dan Peterson
Forum username: redneckMANAIC
Hometown: Monroe Wisconsin
Make/Model/cab and bed configuration: 2004 Ford F250 12 valve rotary pump Cummins out of an 89' Dodge
Engine mods –
Engine: 12 valve rotary pump Cummins out of an 89' Dodge
Tuning: Full power screw precision tuned with a Snap-on Scewdriver!!
Injectors: New stock non I/c
Turbo:
Intake: Custom cold air behind the grill with an AFE wet filter
Exhaust: 3 inch with dual 4 inch tips
Fuel System:
Other: New bearings before the swap
Transmission mods –
Auto/manual: 5r110 with the PCS controller and fordcummins adapter plate/flexplate
Other:
Exterior –
Suspension:
Wheels:
Tires: Bald ones
Other: POWER-*** stickers
Interior –
Audio upgrades: Marine Band Radio
Creature Comforts: Leather Seats and no A/C... removed to save money and time in the swap
Other: Gauge Pod, boost oil pressure and volts, and most important cow manure on the ford floormats
Miscellaneous: Swapped in a manual t-case and tranny is 1-3/8 farther back than stock, so yes custom driveshafts.
Favorite Mod: I love the whole conversion favorite mod is my CUMMINS!!! Turns some heads
Old Jan 10, 2013 | 11:14 PM
Paintballrepins's Avatar
Well I'll give it a shot.
Owner name: Chris
Forum username: Paintballrepins
Hometown: Reading, PA
Make/Model/cab and bed configuration: GMC/2500/RCLB
Engine mods –
Engine: LB7 Duramax
Tuning: EFI Live
Injectors: Stock
Turbo: Stock
Intake: Stock with AFE ProGuard 7 filter
Exhaust: MBRB downpipe/4in into 5in dual Mitre Cut Stacks
Fuel System: AirDog 2 165
Transmission mods –
Auto/manual: NV4500
Clutch/Torque Converter: SB Dual Disk Ceramic
Exterior –
Suspension: 6" RCD suspension lift
Wheels: Aftermarket 16.5" Set of H2s being powdercoated
Tires: 35/12.5R16.5 BFG All Terrains
Other: Cut out 1.5" blocks for body lift, Undercoated up to the body line, Homebrewed Front Bumper
Interior –
Audio upgrades: 600 Watt/1200RMS Rockford Fosgate System, 6 Speakers and 10" sub, Dual Headunit with Bluetooth streaming
Creature Comforts: Bench Seat
Other: Boost/Pyro/Fuel Pressure Gauges set up on A pillar
Miscellaneous: Took me almost two years working weekends to finish her up. Completely taken down to the frame and rebuilt. Just needs a paint job and a new rear bumper.
Favorite Mod: The engine tranny combo, gotta love the handshaker.
Old Jan 11, 2013 | 12:30 AM
Uncle_jesse's Avatar
Owner name: Jesse Ilott
Forum username: Uncle_jesse
Hometown:Victoria B.C
Make/Model/cab and bed configuration: 93 f350 4x4 crew cab longbox
Engine mods
Engine: 97 5.9 cummins
Tuning: 0 fuel plate,afc mod,3200 gsk's,15*pump timing
Injectors:stock
Turbo:Hx35 no waistgate
Intake:home brew
Exhaust:4-5" straight pipe
Fuel System:stock
Other:superduty innercooler
Transmission mods –
Auto/manual: ZF 5spd
Clutch/Torque Converter: luk
Other:fordcummins adaptor
Exterior –
Suspension: 6" skyjacker/ rear airbags
Wheels: 17"
Tires:35" hancook rto3
Other:
Interior –
Audio upgrades: Kenwood media head unit/kenwood 6" fronts/hertz 5x7 rears 2-10"s 1200watt kenwood amp
Creature Comforts:2000 superduty lariet leather front seat / auto meter sport comp boost and pyro
Other:
Miscellaneous: home brew front and rear bumpers, ramsey 12,000 lbs winch
Favorite Mod: cummins conversion .... worth every penny
Attached Thumbnails Febuary TOTM Voting-my-truck2.jpg   Febuary TOTM Voting-cummins-swap-2.jpg   Febuary TOTM Voting-my-truck1.jpg
Old Jan 19, 2013 | 08:22 AM
angelic0-'s Avatar
Owner name: Viktor Agnar Falk
Forum username: Angelic0-
Hometown: Keflavík, Iceland
Make/Model/cab and bed configuration: Dodge RAM 1500 Extended Cab, Short Bed
Engine mods
Engine: 5.9 CUMMINS TURBO DIESEL 12valve P-Pump
Tuning: Custom
Injectors: Marine 370 Injectors
Turbo: Holset HX40 & HX60 in Compound setup
Intake: Custom / BHAF
Exhaust: Custom 5" Downpipe, 4,5" back
Fuel System: Raptor 150GPH, Grid Heater delete
Other: 4k GSK from DDP, 60# Valvesprings from BBD Performance, Maxed Out P-Pump, No Fuel Plate, Tuned AFC, 20° Timing
Transmission mods
Auto/manual: Manual NV4500
Clutch/Torque Converter: South Bend SB-13125FEK
Other:
Exterior
Suspension: Rancho RS 5000
Wheels: American Racing Outlaw II
Tires: BF Goodrich Mud Terrain 35x12,5
Other:
Interior
Audio upgrades: Old Pioneer HU, Alpine Type-R front and rear speakers, JBL 900RMS subwoofer (2000w PEAK)
Creature Comforts:
Other:
Miscellaneous: Truck is a 1500 gasser i converted to a CTD, yet remaining are axle swaps and suspension modifications, ideas of future modifications include 38" Super Swampers, truck is still in progress...
Favorite Mod: 4K GSK / TWINS !!!
Pictures
The site where i host my newest pics is down and i will need to contact an admin to have these posted if it doesn't come up before editing time runs out...
Old Jan 19, 2013 | 11:30 PM
2005Fummins's Avatar
Owner name: Shannon Casey
Forum username:2005Fummins
Hometown:Monte Vista, CO
Make/Model/cab and bed configuration: 2004 Ford F-250 Lariat CC, SB 4x4
Engine mods – Punched .20, balanced crank, ARP studs, new cam, lots of little stuff.
Engine:2001 24 valve 5.9 Cummins
Tuning: None. Edge Insight CTS on the way.
Injectors:Stock, for now.
Turbo:ATS Aurora 3000.
Intake:CFM + horn, custom cold air Spectre dry filter.
Exhaust:5" Turbo Back Diamond Eye, custom downpipe. 3 peice pulse monster manifold.
Fuel System:FASS Titanium 150.
Other: Painted really cool Cummins red!!
Transmission mods – None yet, it's coming sooner rather than later.
Auto/manual:5R110 Ford, PCS stand alone controller.
Clutch/Torque Converter: ATS 5 star.
Other: Custom cooler lines.
Exterior –Tough Country Apache bumper with expanded metal and euro bar option. Linexed to match bottom color of paint. MKM customs 05-07 grille and 1 peice headlights. Showtime Fabrication brushed aluminum winterfront inserts currently in it. It's cold down here!!
Suspension: Stock for now, leveling kit on the way.
Wheels: Stock.
Tires: BFG currently, I hate em.
Other:Old, oily diamond plate tool box in the bed.
Interior – Leather, stock. Santa brought me some Weather Tec floor mats for the front and rear this year.
Audio upgrades:Stock, damn thing is too loud to hear it anyway.
Creature Comforts:Heater works better with the winterfront!!
Other:Just got it back together and the way I want it, now we will make it pretty.
Miscellaneous:
Attached Thumbnails Febuary TOTM Voting-fummins1.jpg   Febuary TOTM Voting-fummins2.jpg   Febuary TOTM Voting-fummins3.jpg   Febuary TOTM Voting-fummins4.jpg
Old Jan 23, 2013 | 12:55 PM
RAW's Avatar
RAW
Default Febuary TOTM Voting
Here are the truck to vote on for Feb!
Old Jan 23, 2013 | 03:47 PM
angelic0-'s Avatar
I have yet to submit the "under hood" pictures...
Old Jan 23, 2013 | 04:16 PM
1993firstgennewbie's Avatar
WHAT ARE YOU WAITING FOR
Old Jan 23, 2013 | 04:17 PM
RAW's Avatar
RAW
As much as I would like to, I can't add them now. Time is up for submitting material. I probably shouldn't make reference to post 43 in the December (Dodge) TOTM submissions. Oops.
