2007 5.9 cummins volt meter reading voltage past acceptable range
Old Jan 23, 2013 | 09:52 AM
CP 2007 5.9's Avatar
Default 2007 5.9 cummins volt meter reading voltage past acceptable range
My truck has recently started dipping in voltage on start up, and today she started reading abnormally high voltage. Also on first start up it sounds like all my gauges vibrate and they delay a second before reading any info.
Any ideas? Batteries? Alternator? Bad ground?
Old Jan 23, 2013 | 04:42 PM
Bigg Redd's Avatar
Possible bad ground(s). Check your grounds and all cables. But could also have a weak or bad battery. If it turns out to be a bad battery, remember to change them both out.
Old Jan 23, 2013 | 07:34 PM
Went to Autozone and it turned out to just be a bad battery. Thanks for the help.
Old Jan 24, 2013 | 10:00 AM
Bigg Redd's Avatar
Right on bro. Glad to help. My job here is done........
