03 power lose
Old Jan 22, 2013 | 01:45 PM
rodeoman12's Avatar
Default 03 power lose
My 03new when it shifts into OD seems like I loose alot of power. Engine noise decreases alot and speed don't climb as fast. New tranny and lift pump. Not sure what going on something not rite.
At times sounds like turbo barking when OD engages
Old Jan 23, 2013 | 07:32 PM
RanchhandTCR's Avatar
Hmm, it be nice to get a scanner on your truck it can be a sensor, or possibly just as easy as a fuel filter... When you say turbo barking you mean in kinda chirps like it does when you build up alot of boost then let off?
Old Jan 23, 2013 | 08:10 PM
rodeoman12's Avatar
i have had the truck for a year it has done it since i bought it. numerous fuel filters so that not it. the turbo does not bark unless i am loaded and it does it like you said. it almost acts like it is starving for air. i dont know what is going on. ever since i bought the truck it seems weak to me.
Old Jan 23, 2013 | 10:02 PM
Can you please answer these questions..
How many miles?
What kind of lift pump? Stock or Aftermarket.
Do you have prolonged starts?
Do you have a Check Engine Light?
Any repairs besides the lift pump.. And did the truck act like this before the tranny and lift pump? thanks
Old Jan 24, 2013 | 05:01 AM
rodeoman12's Avatar
156000 miles. factory replacement lp. Only other thing done is replaced complete cooling system and torque converter cooler. Had this problem before all replacements. Truck is bone stock except billet converter
Old Jan 24, 2013 | 08:24 PM
Hmm, Best thing to do is try to get a scanner on there and check and see what your injection pressure are, map sensor, and see if you can check your wastegate. But one simple thing you can try and do is pull the intake off the front of the turbo check for back and forth and side to side play..
Old Jan 24, 2013 | 09:15 PM
rodeoman12's Avatar
Can scanner tell if injectors and pump has a problem. Or sensor bad also if sensor bad wouldn't CELL be on
Old Jan 24, 2013 | 09:58 PM
not always... a good scanner can read each injector and sensor out put such as a snap on varus.. it can read the out put of the lift pump and high pressure pump...
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
