Duramax getting stuck in snow
Old Jan 14, 2013 | 06:28 PM
xchuckkingx's Avatar
Default Duramax getting stuck in snow
Hello everybody.
I bought a 2002 4X4 Duramax and this thing gets stuck in the snow all the time. I have stock rims and stock tires 245/75/R16. Also when I engage 4 wheel drive and look out the window it seems the front right tire is not spinning?
Is this multiple problems or the stock tires?
Old Jan 14, 2013 | 09:46 PM
turbostang7's Avatar
Get better tires, stay out of deep snow
Old Jan 15, 2013 | 01:13 AM
Tblooma's Avatar
My 01 with blizzaks is pretty impressive, but that tranny bracket looks like it could slow ya down a bit!
Old Jan 16, 2013 | 12:46 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the tires. How much tread is on yours?
Old Jan 16, 2013 | 05:39 PM
tiremann9669's Avatar
What do you expect for a Dmax
Old Jan 16, 2013 | 08:45 PM
Any tire ideas for A/T?
Old Jan 16, 2013 | 08:47 PM
mysterync's Avatar
Cooper at3's go great!
Old Jan 24, 2013 | 04:17 PM
CCPerformance.com's Avatar
Originally Posted by xchuckkingx
Hello everybody.
Obviously the condition of the tire would matter but I've had this problem on occasion regardless of tire if your trying to cut across some semi frozen snow. I got stuck on a friends frozen lawn once in 2wd. In 4wd I got out but it was a pain in the butt.
I found that the tire pressure was too high. If you're running E load pressures this could be an issue. I run my at around 40ish in the winter and not much higher when not towing anything in the summer as well.
Old Jan 24, 2013 | 09:07 PM
Bluetick's Avatar
I've got 285/75/r16 nitto terra grapplers on my 02 D-max and it does great in snow. As for the front tire not spinning I believe that they have a open differential in the front so only one might spin. I could be wrong on that i'm not sure.
Old Feb 26, 2013 | 12:41 PM
Hotforteacher's Avatar
We get a good amount of snow here and for a good all terrain I personally have not seen anything better than the BFG all terrains. Although you really cannot beat a good snow tire. Just really need to change them out in the summer time. Are both your front tires not turning or just the one front?
