Draining coolant on 6.7L for EGR delete.
Old Jan 10, 2013 | 10:58 AM
bigrig73's Avatar
Default Draining coolant on 6.7L for EGR delete.
I was wondering if there was a valve to open to drain the coolant on my 6.7L or do u just pull a hose. I wanna install an EGR delete on the donkey.
Old Jan 10, 2013 | 11:21 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
just pull off the cooler when the motor is cooler.
Old Jan 10, 2013 | 11:40 AM
bigrig73's Avatar
I can see that making a mess.
Old Jan 10, 2013 | 10:58 PM
coors_man_2005's Avatar
You wont lose much coolant at all i wouldnt even think about draning it the cooler holds more fluid then you will drop just sayin just keep the lines elevated and it works fine. and has worked fine on everytruck i have deleted and its not just 1 truck
Old Jan 13, 2013 | 08:18 PM
Brad1103's Avatar
You may loose a cup of fluid, I've done quite a few and never lost much on any of the trucks
Old Jan 14, 2013 | 06:13 PM
jdinny's Avatar
There's a drain on the bottom of the radiator, on the drivers side.
caissiel
Sep 24, 2015 05:37 PM
