triples trouble and twin questions.
Old Jan 8, 2013 | 09:47 PM
97cumminskid's Avatar
Default triples trouble and twin questions.
I'm taking a break from working on my triple setup and started thinking. Would it work if you put a s470 under an hx35 that had the waste gate hole drilled out. Would it spool quick and be capable of around 500hp worth of air
Old Jan 8, 2013 | 10:38 PM
Fox's Avatar
Fox
why would you remove the wastegate? You mean that had the wastegate welded?
Old Jan 8, 2013 | 11:24 PM
No. I drilled out the turbine divider and made the waste gate hole bigger so it would flow more and flow from all 6 cylinders not just the back three.
Old Jan 8, 2013 | 11:29 PM
Fox's Avatar
Fox
that makes no sense. So you're leaving the waste gate open to divert gas AROUND the turbine, instead of through it?
Drilling out the divider just impedes flow with added turbulence....
maybe I'm just misunderstanding...
Old Jan 8, 2013 | 11:36 PM
It still has the flap and works like stock. I was doing research and found some posts About triples that say to drill through the Divider where the waste gate flows.
Old Jan 8, 2013 | 11:38 PM
Fox's Avatar
Fox
. Ah. So you just mean porting and radius'ing the waste gate. Got ya.
As for the divider. I doubt that. ;]
Old Jan 8, 2013 | 11:51 PM
I drilled through the divider. Google it there should be a writ up on it
Turbo Mod
Last edited by 97cumminskid; Jan 8, 2013 at 11:51 PM. Reason: Automerged Doublepost
Old Jan 9, 2013 | 12:02 AM
Fox's Avatar
Fox
Ah... ok ok. Now I understand what you meant. From what I thought you were saying, is that you tried to drill/hog out the septum to try and mimick a T3 housing. You are just trying to Wastegate cylinders 1-3 as well.
Understood.
Old Jan 9, 2013 | 12:06 AM
Yep. You got it. I'm still learning. This is the stuff they don't teach you in school. Ha
Old Jan 9, 2013 | 01:32 AM
angelic0-'s Avatar
ok, WTF ??
How did i not know this !!!
I'm pulling my HX40 off today and doing this.... i don't want uneven pressures in my 6BT !
