truck will not shut off HELP!
Old Jan 7, 2013 | 07:24 PM
bobracing32's Avatar
Default truck will not shut off HELP!
Ive got an 04 cummins and it wont shut off. Anyone ever had any issues with there rigs not shutting down?What do i do or check?
Old Jan 7, 2013 | 07:28 PM
mysterync's Avatar
Do you have any tuners?
Old Jan 7, 2013 | 07:54 PM
Hypertech and bullydog. Havent messed with either in 4-5 months. Has a raptor fuel pump on it, relay went out. Replaced it now it wont shut off. i know the pumps not running. With the key off truck will run. Pull battery cables connect again most dash warning lights are on without key on.
Old Jan 7, 2013 | 07:59 PM
mysterync's Avatar
Sound like a failed ignition switch.
Old Jan 7, 2013 | 08:18 PM
Im not sure everything else with the switch seems to work good. Just wondered if people had ideas.
Old Jan 7, 2013 | 08:35 PM
mysterync's Avatar
Just sounds like an ignition switch. If i get a second tomorrow ill look up and get you a way to confirm it via wiring.
Old Jan 8, 2013 | 07:21 AM
thanks!
I left the truck run with the key out. Ran for about 5 minutes and died. I left it alone a few minutes later the headlights flashed on and off a few times?
Last edited by bobracing32; Jan 8, 2013 at 07:21 AM. Reason: Automerged Doublepost
Old Jan 8, 2013 | 08:19 AM
dangerous1965's Avatar
Check all your grounds! The CP3 will pull fuel even with the pump off! Till it creates a vacuum to strong to overcome!
Old Jan 8, 2013 | 08:31 AM
mysterync's Avatar
Injectors wont fire without current regardless of fuel pressure unless a nozzle is cracked. He would first complain of smoke, misfire,low power and oil dilution if this was the case.
Old Jan 8, 2013 | 11:45 AM
Left batteries unplugged overnight. Shuts off fine today probly a dozen times. However the headlights come on when they want as the trucks off?
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
