6.5 td optical bump
Old Jan 7, 2013 | 06:24 AM
DetroitDiesel's Avatar
Default 6.5 td optical bump
any information on the optical bump? how is it done?
Old Jan 18, 2013 | 04:36 PM
scrappiron68's Avatar
the DS-4 injection pumps uses an optical sensor, that reads a disc inside the pump that measures the timing and fuel. Optical bump is when you move the optic sensor inside the injection pump which fools the ECM into giving it more fuel and timing as the otpic sensor is no longer reading real or actual numbers since it has been moved from the calibrated position. This is a cheap way to add fuel to an electronically injected engine. But i do not recommend it. it makes for touchy throttle, beats the trans, and more. If you want more power get a programmer.
petew
Jul 25, 2015 03:56 PM
penley`
Jun 7, 2015 04:38 PM
airspeed181
Jan 19, 2015 09:00 PM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
