48RE Code P0868
Old Mar 21, 2008 | 04:54 PM
dhaney's Avatar
Default 48RE Code P0868
Hello all,
Coming home last night from work. After coming to a full stop when I started to pull away the truck would move, but acted like the tranny was slipping. Once it got moving it will shift fine, also moves fine in reverse. When checking for codes with the key all that it shows is P0868. Any Ideas ? Trans. pump maybe ?
Thanks in advance, Big_bo
Old Mar 21, 2008 | 05:17 PM
Nitelord's Avatar
I couldn't find that code.
Heres a bump to keep it visible...
Old Mar 22, 2008 | 12:12 AM
dhaney's Avatar
P0868 - Transmission Line Pressure Low. Just wondering if anyone has had this problem.
Thanks for the reply
Old Mar 22, 2008 | 04:54 AM
DB Admin's Avatar
Banned
Check your Fluid
Engine Running and in Neutral
Old Mar 24, 2008 | 08:35 AM
dhaney's Avatar
Diesel Minded,
Thanks for the reply. The fluid level is good.
It only does after it warms up.
Old Mar 24, 2008 | 06:57 PM
DB Admin's Avatar
Banned
What Modifications have you made to the truck ?
Old Mar 24, 2008 | 07:01 PM
2001shrtbedcummins's Avatar
As well as modifications, how heavy and often do you tow? Was the tranny fluid burnt?
Old Mar 25, 2008 | 01:11 AM
dhaney's Avatar
No Mods. No heavy towing, Not burnt. 95000 miles mostly highway
Old Mar 25, 2008 | 02:04 AM
that's strange,
Old Mar 25, 2008 | 02:52 AM
DB Admin's Avatar
Banned
Go to a tranny shop and get a flush done , you may have a blockage somewhere
