I have leak help
Old Dec 29, 2012 | 10:59 PM
jones's Avatar
Default I have leak help
I have a 2004.5 dodge and I have a leak around the pump that's next to the block I check the 3 lines that connects to the pump and it's not comming from there and it's not coming from any lines above it the leak looks like it's next to the block is there anywhere else on the pump I could be coming from or around the pump area thanks guys I'm lost on this one
Old Jan 23, 2013 | 07:32 AM
RAW's Avatar
RAW
I'm not a 3rd gen/CR guy, so what pump are you talking about?
Old Jan 23, 2013 | 08:26 AM
RanchhandTCR's Avatar
if your talking about the power steering you can either get a leak from the front gasket on the pump. Is it oil? or power steering fluid. I also know that the high pressure fuel pump is right up along there too. If its that is it diesel? But they can leak from the front cover housing side.
Old Jan 23, 2013 | 11:59 AM
NadirPoint's Avatar
Need to identify the fluid: oil, steering fluid, fuel, coolant - "what" is leaking?
Old Jan 25, 2013 | 09:49 AM
steved's Avatar
By the way he stated "three lines", it sounds like he's experiencing a leaking CP3, common in cold weather...there is a TSB for replacing the CP3 if you're under warranty (its a STAR authorized part). It will often show up as a drip off the wires to the pump.
It will likely stop once the temperatures get back to normal...mine leaked every time it got cold, and stopped every spring; and that was a STAR replacement pump to fix the exact problem!
Old Jan 26, 2013 | 09:20 AM
dangerous1965's Avatar
Yup CP3!^^^
LariatOutlawGirl
Sep 1, 2015 02:15 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
