05 6.0l Issue
Old Mar 20, 2008 | 09:05 PM
chickbunker's Avatar
Default 05 6.0l Issue
got an 05 350 cc drw it seems to be using coolant and i get a moaning noise sometimes with a high pitched whistle does it intermittently. any thing you guys have run into?
Old Mar 20, 2008 | 09:58 PM
Buckshotmckee's Avatar
Sma't Alec!
Hope this helps!
TSB 07-21-5
10/29/07
COOLANT DEGAS BOTTLE OVERFLOW - 6.0L
FORD:
2003-2005 Excursion
2003-2007 F-Super Duty
2004-2007 E-Series
This article supersedes TSB 07-14-5 to update the Part List.
ISSUE
Some 2003-2007 F-Super Duty, 2003-2005 Excursion and 2004-2007 E-Series vehicles, all equipped with a 6.0L engine, may exhibit coolant venting from the degas bottle cap. The condition typically occurs when operating the vehicle under a load such as trailer towing, uphill driving, or both.
ACTION
Prior to making any repairs, verify the coolant level is not overfull. The new coolant fill level is at the "MIN" line of the degas bottle cold. Overfilled coolant levels will cause coolant to vent from the degas bottle cap. If the degas bottle is not overfull, and is still venting out coolant, refer to the following Service Procedure.
SERVICE PROCEDURE
Complete All Steps In Order As Outlined
1. Check for cross contamination of engine oil into cooling system by inspecting the coolant condition in the degas bottle. If oil is present in coolant, perform the following repair:
a. Replace the oil cooler, refer to Workshop Manual (WSM), Section 303-O1C.
NOTE ON 2004 E-SERIES 6.0L BUILT BEFORE 05/29/2004: IF THE OIL COOLER IS REPLACED, ALSO REPLACE THE HEATER CORE INLET HOSE; THE REVISED HOSE CONTAINS AN INTERNAL FLOW RESTRICTOR (FIGURE 1). REFER TO TSB 05-2-5 FOR ADDITIONAL INFORMATION.
b. Clean cooling system with VC-1 Motorcraft(R) Premium Cooling System Flush. Refer to WSM Section 303-03.
NOTE IT MAY BE NECESSARY TO FURTHER REMOVE ALL COOLANT HOSES (RADIATOR, DEGAS, AND HEATER) AND CLEAN THEM SEPARATELY. OIL TENDS TO ADHERE TO THE RUBBER AND RESISTS NORMAL FLUSHING.
NOTE IN EXTREME CASES, THE RADIATOR MAY NEED TO BE REMOVED AND CLEANED IN AN ULTRASONIC CLEANING TANK AT A LOCAL RADIATOR REPAIR FACILITY.
2. Check for diagnostic trouble codes (DTCs). Then using IDS datalogger, access the following PIDs and road test the vehicle:
^ Manifold Gauge Pressure (MGP)
^ Barometric Pressure (BARO)
^ Exhaust Gas Recirculation (EGR)
^ Exhaust Pressure (EP)
^ Mass Air Flow (MAF)
^ Manifold Absolute Pressure (MAP)
^ Engine Coolant Temperature (ECT)
^ Engine Oil Temperature (EOT)
a. Verify that MGP, BARO, EGR, EP, MAF and MAP PIDs are within specification, and the EP PID value is within 1.5 psi (10.34 kPa) of the MAP and BARO PID values with key on engine off (KOEO). If PIDs are not within specification, or DTCs are retrieved, refer to PC/ED pinpoint tests. Repair any faults then proceed with the TSB.
NOTE OVER-BOOST CONDITIONS (HIGHER THAN SPECIFIED MGP) WILL RESULT IN EXCESSIVE CYLINDER PRESSURES, AND MAY BE CAUSED BY ONE OF THE FOLLOWING: IRREGULAR RESPONSE IN VARIABLE GEOMETRY TURBO, BIASED EXHAUST PRESSURE SENSOR, AND/OR IRREGULAR EXHAUST GAS RECIRCULATION.
b. Verify that ECT and EOT PIDs are within specified ranges (see PC/ED Section 1: Description and Operation of ECT, EOT). EOT should be about 225°F (107°C) when the ECT is 200°F (93°C). If EOT IS NOT within 250 F (14°C) of ECT during the concern, replace the oil cooler. However, first perform all steps through Step 5 before replacing the oil cooler. Refer to Workshop Manual, Section 303-01C.
3. Check for proper operation of the pressure cap and its seal to the degas bottle. Do not remove the pressure cap. As shown in (Figure 2), install the pressure tester to one (1) of the two (2) small ports near the top of the bottle. Then isolate the degas bottle by securely pinching off (or plugging) the other intake deaeration (small) line, and the large hose at the bottom of the bottle between the bottle and the tee fitting. Pressurize the degas bottle by using slow and steady pushes on the tester pump handle (not quick jerking pushes). Pressurize the degas bottle until the gauge pressure levels off typically between 12-18 psi (83-124 kPa).
a. Wait 30 seconds, if the gauge holds steady pressure, the pressure cap and degas bottle fill neck lip are good.
b. If the gauge pressure drops, apply soapy water around the cap to find any leaks. Check the degas bottle fill neck lip for nicks or cracks. Small nicks can be removed by light sanding with fine emery cloth. Re-pressure test, if leaks are still present replace the pressure cap. Re-pressure test again, if leaks are still present replace the degas bottle, Refer to WSM, Section 303-03.
c. After verifying that the degas bottle and pressure cap are in good condition, proceed to Step 4.
NOTE A DEFECTIVE EGR COOLER CAN CAUSE COOLANT TO VENT OUT OF THE DEGAS BOTTLE AND APPEAR SIMILAR TO HEADGASKET FAILURE.
4. EGR COOLER TEST: Install a pressure tester in-line with the degas bottle hose using Rotunda 014-R1068 adapter. (Figure 3)
a. Pressurize the cooling system until the gauge pressure levels off.
b. Inspect for external leaks especially in the heater core area. Replace the heater core if necessary, refer to Workshop Manual, Section 412-02. Refill the system and proceed to Step 4c.
NOTE ON 2004 E-SERIES 6.0L BUILT BEFORE 05/29/2004: IF THE HEATER CORE OR OIL COOLER ARE REPLACED, ALSO REPLACE THE HEATER CORE INLET HOSE; THE REVISED HOSE CONTAINS AN INTERNAL FLOW RESTRICTOR. REFER TO TSB 05-2-5 FOR ADDITIONAL INFORMATION.
c. Raise rear of vehicle 2' (61 cm) so front of vehicle is angled down. Pressurize cooling system with pressure tester and remove the EGR valve; inspect for coolant in the intake manifold at EGR valve location. Maintain pressure for up to 15 minutes. An EGR cooler gross leak will produce coolant in the intake manifold almost immediately. It will take up to 15 minutes for coolant to be evident in the intake manifold for the smallest EGR cooler leak. If coolant is present in intake replace the EGR cooler; refer to WSM, Section 303-08. (Normally when the EGR cooler has failed, there will be coolant in the exhaust. Hydro locking of the engine is also possible.) Refill the system and proceed to Step 5.
NOTE REPLACE THE OIL COOLER AT THIS POINT IF NECESSARY AS OUTLINED IN STEP 2.
CAUTION COOLANT ENTERING ANY COMBUSTION CHAMBER MAY CAUSE A HYDRO LOCK CONDITION. EVACUATE INTAKE PASSAGES AND COMBUSTION CHAMBERS OF ALL LIQUIDS. REMOVE GLOW PLUGS (REFER TO WSM, SECTION 303-07B) TO ASSIST IN VENTING LIQUID FROM COMBUSTION CHAMBERS, BEFORE ENGINE IS STARTED.
5. With the pressure tester still installed as outlined in Step 4, release cooling system pressure, leaving the tester in place. Seal pressure bleed. Drive the vehicle at Wide Open Throttle (WOT) / high load / maximum boost. Observe whether the cooling system pressure exceeds the holding pressure of 12-18 psi (83-124 kPa) noted in Step 3, and/or if coolant is venting through the degas bottle cap.
a. If pressure is not greater than the holding pressure noted in Step 3, and no venting from the degas bottle occurs, perform Step 7 (if applicable) and return the vehicle to the customer.
b. If cooling system pressure is greater than the holding pressure noted in Step 3, and/or the degas bottle cap vents, replace the head gaskets. Refer to WSM, Section 303-01 C for head removal/installation and head flatness specification, check the surface of the heads for flatness and/or imperfections. Refer to WSM, Section 303-00 for the cylinder head flatness measuring procedures. Use the following revised head bolt torque sequence and specifications. (Figure 4)
6. Ensure the cooling system has been thoroughly flushed if any contamination had occurred, and new antifreeze is installed after all repairs have been completed. Refer to WSM, Section 303-03. Make certain to follow the cooling system air bleed procedure, or additional failures may result.
7. For 2004 (built after 9/29/03) - 2006 F-Super Duty and 2004 (built after 9/29/03) - 2005 Excursion: reprogram the powertrain control module (PCM) to the latest calibration using IDS release B39.12 and higher. This calibration contains a revised cooling fan strategy to help reduce the occurrence of coolant venting. Calibration files may also be obtained at the website.
CYLINDER HEAD HANDLING
^ Avoid banging, dragging or scratching the cylinder head at all times. When removing the cylinder head, lift the cylinder head straight up off of the dowels so as not to nick the cylinder head.
^ Once the cylinder head is removed, place the cylinder head on a bench with the gasket side up. If the gasket surface must be turned down, use a piece of clean cardboard on the bench surface to protect the cylinder head from damage. Do not allow the cylinder head to slide on the gasket surface, even on cardboard.
Old Mar 20, 2008 | 09:59 PM
Sma't Alec!
Continued........
CLEANING THE CYLINDER HEAD AND DECK SURFACE
The only tools approved by Ford Motor Company for cleaning the cylinder head and deck surface are plastic (Figure 5) and wood scrapers, combined with use of Ford approved cleaners. Ensure that the mating cylinder block deck surface is completely free of solid contamination, corrosion, and fluids.
NOTE STAINING OF THE METAL SURFACE IS CONSIDERED NORMAL AND DOES NOT AFFECT SEALING ABILITY.
CAUTION DO NOT CLEAN DECK SURFACES UNDER ANY CIRCUMSTANCE WITH STEEL RAZOR BLADES, ROTARY ABRASIVE DEVICES, OR ABRASIVES INCLUDING: ROLOC AND 3M BRANDED SCOTCHBRITE PRODUCTS OR EQUIVALENTS, ROTARY WIRE BRUSHES, SINGLE HANDLED WIRE BRUSHES, HAND ABRASIVES SUCH AS SANDPAPER OR EMERY CLOTH, ANY CARBON STEEL BLADE. THESE PRODUCTS WILL CUT AND DAMAGE DECK SURFACES RESULTING IN LEAKS. ABRASIVE PARTICLES MAY ALSO ENTER THE ENGINE CAVITIES CAUSING INTERNAL ENGINE DAMAGE. USE OF THESE TOOLS CAN ALSO GREATLY AFFECT THE FLATNESS OF THE SURFACE.
Parts Block
OTHER APPLICABLE ARTICLES: 05-2-5
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT072105 Use SLIS Operations If Actual
Available; Claim Additional Time
Diagnosis Or Labor
Performed As Actual Time
DEALER CODING
CONDITION
BASIC PART NO. CODE
6051 42
Old Mar 20, 2008 | 11:04 PM
TEXASPOWER's Avatar
bet you a hundred its the egr valve mine has done it alot and its doimg it right now i just dont have time to take it in
Old Apr 9, 2008 | 02:23 PM
RTL Garage's Avatar
Any Follow Up On This?
Old Apr 9, 2008 | 08:32 PM
JON's Avatar
JON
Member
Default Coolant
Is it pushing coolant out the over flow or puffing white somke? I have had several whistle out of the coolant over flow cap when under extreme pressure. Rule of thumb, out the over flow = headgaskets out the tail pipe = egr cooler and possibly oil cooler.
Old Jun 14, 2008 | 09:02 PM
well i cooked the turbo, and replaced my rad, went away for the weekend lost 14 liters of coolant and was back in for the heads. now its going back in again cause they f**k up on something oil leak, abs is F****d and the covered my *** end in oil. Got the arp studs in it now :P what are your guys recommendations for intake, chip, exhaust?
Old Jun 15, 2008 | 12:50 AM
BLACK_06POWERSTROKE's Avatar
intake-afe dry, chip-sct xcal3 w/custom tunes, mbrp 4" turbo back
Old Jun 15, 2008 | 11:24 AM
JON's Avatar
JON
Member
Default !
yep, what he said! Cant get any better then that on a 6.0.
Old Jun 16, 2008 | 12:20 AM
afe dry. which type there are so many choices
