04 water(RAIN) leak on floor mat?????
Old Dec 24, 2012 | 04:16 PM
wristpin's Avatar
Default 04 water(RAIN) leak on floor mat?????
Anybody had any problems with rain leaking onto floor mat just beneath the glove box area?
Leaked before glass replacement and continued after new windshield installed. Can`t seem to see where it is coming from and it is not coolant
I suppose it will go away when summer gets here and then dry out/OR INSTALL A BILGE PUMP
ANYone had a problem like this leak?
THANKS
AND MERRY CHRISTMAS TO ALL YOU BOMBERS
Old Dec 24, 2012 | 04:34 PM
Bigg Redd's Avatar
I know youre indicating "rain", but do you or have you run your a/c? Maybe a leak in the heaterbox allowing water, from condensation, to leak in. Also defective/ worn door weatherstripping, possibly the same for the windshield weatherstripping. Maybe have someone spray water while youre inside looking for the leak. Does it get damp or soaked?
Old Dec 24, 2012 | 07:32 PM
ecjammer's Avatar
Do you have clearance lights? They can crack and the gaskets can crack, letting moisture in the truck. I'd check them.
Old Dec 25, 2012 | 02:01 PM
wristpin's Avatar
no clearance lights .
So it looks like I will try the water hose spraying thingie as suggested.
I will pull the glove box and look
Well as usual, it raining so I will not need any help spraying water.
Thanks for the suggestions..............
Old Jan 1, 2013 | 12:24 PM
wristpin's Avatar
found leak--seal between firewall and heater box cold air inlet. Tightened nuts and it stopped, well it seems to have stopped
Old Jan 2, 2013 | 10:34 AM
Bigg Redd's Avatar
Way to go man! If it leaks again, try some silicone sealer. Glad ya got it.
LariatOutlawGirl
Sep 1, 2015 02:15 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
