leak down question
Old Dec 19, 2012 | 05:24 PM
mikej's Avatar
Default leak down question
did a leak down test and got a huge differance in percentage #1 cylinder was 77%#2at75%3at4% 5at3% all readings were with piston at tdc.only had 30 psi to test with i know 40 psi will work even with lower pressuer i would think i have head or piston problems.let me know if anyone thinks i may have missed something.
Old Dec 19, 2012 | 06:52 PM
TheOtherNick's Avatar
where is the air going? Coolant bubbles? Sounds like the head gasket failed between cylinder 1 and 2.
Old Dec 24, 2012 | 02:35 PM
mikej's Avatar
realy could not tell where the air was going i can say no bubbles in the coolant no air out of blow by tube or dip stick it just sounded like it was leaking near the adapter/test fitting.the odd thing was that it ran smooth until the temp got to 200* then as soon as you would give it a little hard throttle it would bring on a dead miss.if you need just simple yes or no questions to figure it out i would be glad to do so.this may be a forgone conclusion cause i will pull the heads in a few days and will tell all.Isure hope your right about the head gasket trust me.
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ItsAChummins
May 15, 2015 05:02 PM
Mike0885
Feb 28, 2015 03:16 PM
ash23k
Dec 30, 2014 08:31 PM
