Stumped P1740
Old Dec 15, 2012 | 08:28 PM
36Valved I6s's Avatar
Default Stumped P1740
I just rebuild this trans in my truck. its a late model 2006 put in a transtar triple disc convter new alto clutches sonnas 2nd gear super servo sun coast billet band anchor and apply par used oem 5:1 lever new sonnax accumlator piston new gaskets oem front pump low rev band an superior shift kit.....everything shifted fine for the first 220ish miles then threw the code and now i dont have lock up in 3rd or 4th.....put in a new borg warner gov pressure solenoid and new tcc od solenoid an still same issue....
Anyone have any input on this????
Old Dec 18, 2012 | 04:58 AM
Diesel Addict101's Avatar
You may have a bad connection? Did you check compatibality?
Old Dec 19, 2012 | 12:09 AM
Its not any connection issues...spoke with converter company...transtar an gonna pull it out an maybe at this point try to get my money back n get a sun coast unit....so i dont gotta deal with pullin the trans again....an inspecting it all once more an praying to the diesel gods i didnt wipe out a clutch pack...or any other internals
Old Jan 24, 2013 | 12:07 AM
So to update the issue...pulled trans pull it apart the tcc cover plate had loosened an had no pressure to apply the converter clutch. Trans goes in tomorrow also added a new hd one piece input shaft from sonnax also a new DTT flexplate with arp bolts holding it in!
smokeyfranklin
Feb 19, 2015 07:29 PM
