Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
How to get better mpg? Lbz DMax
Old Dec 14, 2012 | 07:40 PM
1959JD630's Avatar
Default How to get better mpg? Lbz DMax
I have an 06 lbz dirtymax stock right now. I plan on doing a 4" turbo back exhaust S&B cold air intake and possibally efi live. Is there anything else I can do for fuel millage?
Old Dec 15, 2012 | 07:25 PM
2004LB7's Avatar
Keep efi live on your list, that will net you the most gain
Old Dec 19, 2012 | 09:41 AM
19psi's Avatar
drive slow and use stock size tires.
Old Dec 19, 2012 | 11:31 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Intake, tune, and exhaust will help a ton! But also keeping your foot out of it all the time will help the most
Old Dec 23, 2012 | 05:09 PM
jevanb's Avatar
I am only getting 15 city and 20-21 hwy with my mods and I drive like miss daisy
Old Dec 24, 2012 | 08:36 AM
1959JD630's Avatar
Ha yeah keepin the petal soft is pretty hard when you got that 360 stock horse under you and you have a bunch of powerchokes and ***-a-parts wanting to mess with you . But I finally got my truck on the road ( registered and insured ) and I took it on the highway and the odometer said I was getting 21 mpg with a full cab and a quad in the bed but yet the only thing I did to it was cut the muffler and cat off so my exhaust ends right about under the passengers *** but is that O.D mpg reliable?
Old Dec 24, 2012 | 09:16 AM
jevanb's Avatar
you might of been close but all DIC are off, next time fill to spill ,drive, then fill to spill.. how you stand the exh under the cab and no muffler?? must sound terrible and LOUD.. I put a muffler delete pipe in and removed after 2 days, sounded horrible and could not hear the radio, hook up the 13k camper and it was worse..
Old Dec 31, 2012 | 10:09 AM
1959JD630's Avatar
It's honestly not that bad I can listen to the radio no problem I can say it's defffenetly not nearly as bad as my brothers straight pipe lb7 with the pipe out the rear
Old Jan 1, 2013 | 08:46 PM
19psi's Avatar
that's usually about as good as you're going to get for something that weighs 7000lbs. dont' believe the guys telling you they're getting 25 on the highway.
Old Jan 3, 2013 | 05:32 PM
1AMatt's Avatar
Agreed... 20 Mpg in a 3/4 ton truck is pretty good!
