Ditchbanger
Old Dec 8, 2012 | 05:24 PM
DITCHBANGER62's Avatar
Default Ditchbanger
I have an 02 duramax with fuel leakin down the back of the motor. It appears to be coming from under the fuel reg, but i am not sure cause you cant really see up under it. Has anyone had a fuel problem like mine?
Old Dec 9, 2012 | 01:58 PM
2004LB7's Avatar
I one had a banjo bolt down by the cp3 Leak and fuel was dripping out the back. There are numerous fuel lines in the valley of the engine, high pressure, supply, return, etc. The easiest way might be to remove the turbo horn and other small items on top and get a flashlight out and look in the valley for the leak. Mine only leaked when the engine was running so I had to start the engine to see it.
