HPOP or injectors?
Old Dec 4, 2012 | 08:33 PM
iam4x4's Avatar
Default HPOP or injectors?
Yes having troubles with the 6.0
It sounds like its misfiring. Hooked up to a tester and said 2 injectors aren't working. And sometimes it hops between 500-1500 rpm really suddenly. My ficm and an injector was just replaced 1000 km ago. Need help. Heard it could be the STC or HPOP.
Also it has less power ten my previous 6.0 and a lot worse fuel economy and needs more rpm to stay at highway speeds like 21-2200 rpm just to maintain up to everyone . I always use fuel conditioner every time I put any fuel in it
Old Dec 4, 2012 | 09:33 PM
bobfbigman's Avatar
Bad injectors can definately cause a miss. The STC fitting going bad will cause a "no hot start" condition, if you haven't updated the fitting and the standpipes and dummy plugs keep in mind it is a good idea to replace them before they leave you stranded somewhere because they will fail eventualy
Old Dec 4, 2012 | 09:37 PM
iam4x4's Avatar
Would those be the problem?
Old Dec 4, 2012 | 09:58 PM
bobfbigman's Avatar
this problem is most likely the injectors, have you tested the FICM? even though it is newer it is still good to test it, you can find the test procedure in the sticky section at top of 6.0 section
Old Dec 4, 2012 | 11:03 PM
iam4x4's Avatar
FICM is okay. Could it be fuel pump? But the codes say its a mechanical problem with injectors
And I just noticed that there's a little oil leaking slowly can't find where from but it lands down by the rad on drivers side
Old Dec 5, 2012 | 07:56 AM
Mdub707's Avatar
Probably needs those 2 injectors replaced...
You can try adding some rev-x and see if it helps. A lot easier and cheaper than doing injectors...
Old Dec 5, 2012 | 12:32 PM
iam4x4's Avatar
There is no rev x around here. But would those 2 injectors make it hop like that?
Old Dec 5, 2012 | 01:42 PM
Mdub707's Avatar
Yeah... ever tried driving a V8 gas car and pulling two of the spark plug wires? Same idea...
Order rev-x online, that's how most of us get it. You can get it right from the site sponsors. Rev-X the company is a sponsor here. PM sunsetsky
Old Dec 5, 2012 | 06:24 PM
bkmac's Avatar
Got mine here - also a site sponsor and free shipping
KT Performance
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
