Truck won't start
Old Dec 3, 2012 | 11:01 PM
01LB7Duramax's Avatar
Default Truck won't start
I was working on a 2000 f350 7.3 it had trouble starting so I replaced 2 glow plugs and the relay. Let it set over night it was fairly cold outside started great. Pulled it back into the shop to clean off the engine cause I also replaced the water separator drain and I was cleaning ip the fuel in the valley. Tryed starting it after that wouldn't start found that the ipr connector was shorting together replaced that cranked on it for ever finally started. So I went And drove it to get the air out of the system. Pulled it back into the shop. Still started hard. Watched icp it slowly came up and fired at about 1000psi. Spec to fire the injectors is 500. Finally got it to start ok. Over the past few days starting got worse and today it just wouldn't start. Any ideas to help out I'm at a loss.
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
