Coolant system pressure issues
Old Nov 23, 2012 | 08:19 PM
1ton butcher's Avatar
Default Coolant system pressure issues
In need of some thoughts, coolant system is preassureing up and pushing fluid into resivore. Only when it idles and I get in and accelerate over 2500rpm. The coolant is around 145degrees before taking off. I've changed thermostats thinking that was issue, not the case. I have an h&s egr delete and am wondering if it is because of that style. Had system pressure tested to verify head gasket. Just weird. Thanks.
Old Nov 23, 2012 | 10:28 PM
RAW's Avatar
RAW
Is the coolant not returning from the reservoir? If so, it may be a faulty radiator cap.
Old Nov 23, 2012 | 11:19 PM
No it's not. I replaced the cap and no change. But if I hold my hand on there it will draw it back into system. It's weird.
Old Nov 24, 2012 | 08:14 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
if the water pump and thermostat is working properly, they can be only the head gasket. here is a simple test you can do. let the truck sit over night after running. the next morning crack the rad cap. if they are big pressure there you have a head gasket leaking.
Old Nov 24, 2012 | 08:21 AM
RAW's Avatar
RAW
But the system was pressure checked, and held up fine. I guess it is possible a head gasket would allow air into the coolant, but not coolant into the cylinders. It is interesting how head gaskets fail.
Old Nov 24, 2012 | 08:33 AM
diesel pap's Avatar
the 6.7 seems to seal back at low boost. at least that is how mine started. in my opinion the best test is the morning after. if they are big pressure there if can only come from one place
Old Nov 24, 2012 | 07:16 PM
With it being a closed system wouldn't it hold some pressure? I have a 16lb now but why won't it draw the coolant back?
Old Nov 24, 2012 | 07:24 PM
diesel pap's Avatar
it will have very little pressure if the head gasket is ok. as the temp cools down so does the pressure.
Old Nov 27, 2012 | 08:40 PM
coors_man_2005's Avatar
Head gasket. I wouldnt run the factory gasket again. I would install studs and run the vulcan head gasket.
Old Dec 24, 2012 | 05:12 PM
I went to Vulcan performance and they sell a victor gasket. Is this what you were referring to?
