Stack and Leveling Kit Questions
Old Nov 21, 2012 | 08:57 AM
JBSedon's Avatar
Default Stack and Leveling Kit Questions
What are the differences in sound and power, if any, between the sizes? I am trying to figure out whether I should get 6 inch or 7 inch.
In my intro post, something was mentioned about having to get different blocks from a 350 if I want the Sinister Level kit? Is there a kit out for the 250 that I dont have to get other parts for or anything?
Old Nov 21, 2012 | 09:14 AM
c-tane's Avatar
Did you have a leveling kit question too or where you just wondering what height to level off off those stacks so they don't rub the overpasses?
Old Nov 21, 2012 | 09:18 AM
JBSedon's Avatar
Haha. There are two questions there.
Old Nov 21, 2012 | 01:32 PM
Mdub707's Avatar
Most of the leveling kits out there are 2.5" leveling pucks. You can just get some smaller ones from ebay if you want. I did the 2.5" pucks (aluminum blocks) and the stock F350 blocks.
As for the stacks... 6" or 7" you probably wont notice a difference. Ears will bleed regardless. Mine are 6" for reference. I think 7's are too big in a dual seutp, but a single 7" would look cool.
Old Nov 22, 2012 | 01:01 PM
Karls03's Avatar
1. I terminated my exhaust at the axle and it can get pretty obnoxious, imagine if it was up higher behind the cab.
2. Just save your money and get a REAL lift. Slipping in a spacer can roll the axle forward when the trailing arms go down in the cause/effect cycle. This is effectively adding negative caster and making it like driving a clown car. The track bar is more sensitive to lifts in coil sprung trucks, too. Better factor in a steering stabilizer.
DON'T stack blocks when you're doing this. If you do a 3 inch lift up front, a 5 inch block from a Dodge Ram will get you leveled up in the back (stock is no lift in front and 2.5" block out back). # inch is also about all the farther you can lift a truck without needing a dropped pitman arm (althogh you will need to length the adjustment sleeve on the drag link).
99-04s are mucho more forgiving in leveling kits because they use leafs.
Old Nov 22, 2012 | 03:17 PM
Mdub707's Avatar
Agreed, don't stack blocks.
However adding a 5" block in the rear is just going to put the rear higher than the front. A 2.5" leveling kit up front on an 05-07 F250 ends up putting the front higher than the rear. They sit almost level factory. The F350's of those years sit higher in the rear (taller block) To level either one, the 2.5" spacer up front and the stock F350 blocks in the rear (F350 obviously already has these, and F250 would need them). I'm not suggesting adding the stock F350 and F250 blocks together... take the stock F250 blocks OUT and put F350's IN.
Stock F250 block is roughly 2 1/2" and the stock F350 blocks are like 3 5/8" if memory serves.
Mine uses the 2.5" spacer under the coil, stock everything else up front, no track bar drop bracket, no adjustable track bar, no steering stabilizers etc... but it's the cheap way to lift it. I will definitely be getting an adjustable track bar at some point, it just hasn't been too high on the priority list. I really want to just get the full PMF 3 link front end setup. For the rear, I just swapped on the F350 blocks and u-bolts.
Old Nov 23, 2012 | 10:19 AM
Karls03's Avatar
Yeah, I guess a 4in front coil and a 5in Ram block would be closer to level. Personally, I like a little rake so it will level out when loaded.
But to get back on track, I did a leveling kit, shackle drop, then finally a spring lift fore and aft. I could have bought an OUO or some other high dollar/high performance lift with all the money I spent. If you even THINK that you would want a full lift, don't even mess with a leveling kit!
Oh yeah, wouldn't a track bar drop bracket be cheaper/better for geometry? These suspensions travel in an arc because of the track bar. Therefore, while the axle will be centered at ride height, during articulation it would push more left during extension/right during compression. This is why I believe that if you use a dropped pitman arm, use a drop bracket for the track bar, otherwise they will bind sooner or later trying to follow different arcs.
Old Dec 3, 2012 | 01:19 PM
JBSedon's Avatar
I don't want to lift my truck, I just want to level it out. I think I'll go ahead and order the 2.5 inch leveling kit from Sinister, and find a set of 350 blocks for the rear.
I am going to go ahead and do the dual 6" stack on it. I almost took the muffler off this weekend, but when I looked at it, I figured it would get unbearable loud in the cabin, so I'll just wait for stacks.
Old Dec 3, 2012 | 01:26 PM
Mdub707's Avatar
Stacks are going to be the loudest in the cab for sure. I ran a stock exhaust with a cat and muffler delete before, and it wasn't loud in the cab at all. In fact I was always rolling the windows down when going under bridges etc to hear it. It screams in tunnels etc, but with the windows up there is no drone and you likely wont hear it any louder than stock.
With stacks on the other hand... I'm running 4" turbo back into 6" mitres, no cat, no muffler. I'm looking at adding a muffler. Towing anything, you wont be able to carry a conversation with the person in the passenger seat. Seriously. Once up to cruising speed and it shifts into OD and the converter locks... quiet again.
Old Dec 3, 2012 | 01:55 PM
Karls03's Avatar
That's a pretty big contradiction you just posted there. If you think it's going to be loud without a muffler dumping by the rear bumper, how loud is it going to be without a muffler dumping behind your head!?!
