6.5 oil pressure
Old Nov 19, 2012 | 11:08 PM
TheSethBuckinDavis's Avatar
Default 6.5 oil pressure
When I idle or drive at low rpms, my oil pressure goes to 0 but when im driving it usually runs at 40...
Old Nov 20, 2012 | 01:12 AM
racer55's Avatar
Very likely you have a bad sending unit.A mechanical oil pressure gauge Tee'd in to the oil port is the only way to know for sure since you might need the switch to run the LP.
AC Delco only for electrical replacements,BWD are very bad switches.
What year engine?
Old Nov 20, 2012 | 08:50 AM
95 in a 94 Body
Old Nov 20, 2012 | 08:54 AM
racer55's Avatar
Should be no issue wiring wise,get a delco sending unit and google "OPS relay mod" while you are at it-it is worth the effort.
Check LP operation as well.
Old Nov 20, 2012 | 06:59 PM
Alright thanks
Old Nov 25, 2012 | 02:21 PM
dogbone's Avatar
where is the oil pressure switch on a 1995 6.5
Old Nov 25, 2012 | 06:38 PM
racer55's Avatar
Should be just in front of the fuel filter manager in the engine valley.
If you have a later model block it could be tucked under the intake closer to the middle/rear of the valley.
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
Gomerpile79
Apr 9, 2015 03:45 PM
jhprice
Mar 29, 2015 09:36 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
