Do I need rebuild my engine???
Old Nov 19, 2012 | 05:35 PM
Dukecdn's Avatar
Default Do I need rebuild my engine???
I have replaced all 6 injectors. The engines had white smoke out the exhaust engine shaking real bad and a knock could be heard some fiuel was coming out the exhaust as well. After injectors were put in I still have white smoke,knocking,still shaking. No fuel out the exhaust. We now notice that the crank case vent has oil coming out. Which could explain why I go through oil. Once the engine gets up to running tempature the smoke,knocking and shaking goes away.
The mechanic thinks it is the piston rings are shot in #1 and #3 because when he shut the fuel of those cylinders the engine did shake and only dropped 50 rpm. The other cylinders shook the engine and dropped 150 rpm.
I haven't done a compression test yet. I just want to make sure it is the rings and nothing else before I spend thousands of dollars on a rebuild and that is not the problem.
Thanks...
Old Nov 19, 2012 | 06:23 PM
Farmboy 2.0's Avatar
My guess is its actually the rings in 5 and or 6. Those are the most common ones to break on the 06-07 commons rails. It normally takes about a in of the ring out. Id have him do a compression test and go from there
Old Nov 19, 2012 | 09:34 PM
RanchhandTCR's Avatar
do you have fuel in your oil also???
burndiesel
10
Feb 7, 2023 01:15 AM
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
coryfast
Jul 23, 2015 09:00 AM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
