1996 7.3 jet sound at cold start up
Old Nov 13, 2012 | 11:53 PM
SCOTT6291's Avatar
Default 1996 7.3 jet sound at cold start up
My truck used to make a loud jet like sound at cold start as soon as you would touch the break it would stop. not making sound any more something to be worried about?
Old Nov 14, 2012 | 01:27 AM
SyKoReApEr's Avatar
Its the turbo spooling up (or so iv been told) mine does it to, it sounds like a rush of air throug the exaust
Old Nov 14, 2012 | 01:55 AM
MossBack's Avatar
Exhaust back pressure valve. It is actually blocking airflow on the outlet of the turbo. Creates heat and warms up truck. Perfectly normal so don't worry just drive it.
Old Nov 14, 2012 | 08:52 AM
95powersmoker's Avatar
If under the same cold conditions, it isn't doing what you describe, then yes, might want to look into it. It's your EBPV Exhaust back pressure valve.... It should be doing exactly what you described...
Old Nov 14, 2012 | 11:21 AM
SCOTT6291's Avatar
It does it for only a second, Used to sit and idle with this sound until it warmed up. EBPV bad maby. Thanks for the reply
Old Nov 14, 2012 | 12:46 PM
CSIPSD's Avatar
More then likely its your back pressure sensor that is bad, not the valve itself.
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
