97 dodge cummins spitting and sputtering
Old Nov 13, 2012 | 09:55 PM
rascal347's Avatar
Default 97 dodge cummins spitting and sputtering
My 1997 dodge cummins wont stay running and when it does it will spit and sputter, i change fuel filer, cleaned the sock, removed all injectors and cleaned them still the same peoblem. it started with i ran bio diesel in my truck
Old Nov 16, 2012 | 11:12 PM
lodal cummins's Avatar
Did you clean the prefilter????? Maybe even check the and replace the OFV
Old Nov 17, 2012 | 10:20 AM
angelic0-'s Avatar
Way advanced timing ?
Kidding aside, i'm guessing you clogged a filter or screwed up your lift pump :P
do you still have the "biofuel" in it or have you run multiple tanks of diesel in it afterwards ?
i had a filter clog up on WVO, i was advised to use run Kerosene through my system so it would clean up...
Old Nov 19, 2012 | 07:49 AM
rascal347's Avatar
all filters were replaced and the whole system is cleaned.
Old Nov 19, 2012 | 08:13 PM
I say start it up and crack one injector at a time. Sounds like air in the system. Or the bio fuel may have gummed up your lift pump not allowing proper fuel flow.
Old Feb 20, 2013 | 10:28 PM
NEWBIE 98's Avatar
check your overflow valve. and if you still have a fuel heater it can make you loose prime if its burned up. but first follow the air bleed procedure. especially the supply side of the injection pump. my OV was letting off at 10psi and the diesel guy said the injection pump could run ahead of the transfer pump by sending fuel to the tank before the TP could build pressure. Runs great now but have a leak on the injectors. black smoke at every gear change and fuel leaking down the block and itty bitty bubbles withfuel coming from injector socket #3
