Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
what to do first?
Old Nov 13, 2012 | 06:48 PM
somkincummins95's Avatar
Question what to do first?
i bought a 06 duramax its stock i have a cummins im tuning up but the duramax is alot different then cummins i want the efi live tuner around 500 to 600 hp what needs to be changed first? especially transmission
Old Nov 17, 2012 | 10:07 AM
BriteWhiteRam's Avatar
A lot needs to be changed to get 600hp
the trans i would go with a suncoast GMAX6 kit or a PPE stage 5 kit
you need a bigger turbo, better pistons, better rods, bigger injectors, dual CP3's, lift pump, head studs, tie-rod sleeves
thats about all I can think of for hard parts
500hp you could get away with trans upgrades, little bigger injectors(to get the pulse width down) lift pump, and tie-rod sleeves, but it would all probably be on borrowed time
the duramax seems to be happiest in stock form around the 400-475 range, it should last there for quite a while
Hope this all helps
Old Nov 20, 2012 | 06:53 PM
yes thank you besides efi live is a banks tuner good? or which would be better?
Old Nov 22, 2012 | 01:59 AM
2004LB7's Avatar
Efi live. Banks is good but efi live is unbeatable.
Old Dec 23, 2012 | 05:13 PM
jevanb's Avatar
^^^^^^so true
