lb7 vibration/misfire
Old Nov 5, 2012 | 09:48 PM
puresilver66's Avatar
Default lb7 vibration/misfire
Sorry for long story on first post. Got an 02 lb7 with 90,000 miles on clock. Engine runs like it has a misfire. Also has crankcase pressure at oil filler cap but no smoke(pulses cap up and down about 1/2 inch in hand). Compression check is 400 psi on all cylinders. Fuel rates were off on 3 cylinders so it got new injectors. Fuel rates are now in order now but still has misfire/vibration. Also pulled balancer off front of engine to check for sheer, no problem found. The longer the truck runs the worse it runs. Any help would be appreciated. At wits end.
mlknutzen
Oct 1, 2015 10:56 AM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
dshopex4
14
Apr 15, 2015 09:40 PM
Adam Sanders
LB7 Performance
Jan 21, 2015 06:57 AM
Trevlar11
Dec 21, 2014 03:16 PM
