6 blade, 7 blade, or 8 blade??
Old Nov 2, 2012 | 12:25 AM
DieselObsession76's Avatar
Default 6 blade, 7 blade, or 8 blade??
I've decided I'm gonna spend the $275 on the 60mm compressor housing for my hx35, but I don't know what wheel I should get... 6, 7, or 8 blade?
Old Nov 2, 2012 | 12:53 AM
Fox's Avatar
Fox
you need the 40 center section, or your have to have yours lathed out.
also... 6 blade. Your spending about twice what you should on a housing btw...
Old Nov 2, 2012 | 01:19 AM
Its Gillett diesels upgrade, according to them it'll go right on but don't know much about it
HX Upgrade Compressor Housing & Wheel (60mm, 8 blade)
That's the part... whatcha think?
Last edited by DieselObsession76; Nov 2, 2012 at 01:19 AM. Reason: Automerged Doublepost
Old Nov 2, 2012 | 11:41 AM
Fox's Avatar
Fox
Ah. I see. That should not be an actual 40 then. Just an upgraded 60mm compressor. Since you still have to have it balanced... I wouldn't evenconaider for the money
Old Nov 2, 2012 | 01:06 PM
93_Fummins's Avatar
I thought the compressor wheel was zero balanced itself? I put Gillett's 60mm 6-blade on my H1C on my 1st Gen and just put it on; no balancing it, and the compressor appeared to have balance notches machined into it already hence the zero assumption...
Old Nov 2, 2012 | 01:47 PM
Fox's Avatar
Fox
anything spinning at 80,000 rpms needs to be balanced...
Old Nov 2, 2012 | 02:14 PM
1993firstgennewbie's Avatar
what is this supposed yo do for you I have a hx35 on my 93 and it is pullin 37 psi. does it spool faster or give you more boost
Old Nov 2, 2012 | 02:18 PM
Fox's Avatar
Fox
most boost at about the same spool.
I would not bother. You can buy a full super40/35 for about the same price.
Old Nov 2, 2012 | 03:32 PM
93_Fummins's Avatar
I cannot disagree with that; it's basic physics. However, not being a turbine specialist, I'm merly questioning what balancing a turbo truly entails. Everything being concentric, I would assume, in theory, that a zero balance of each individual component would net you pretty close to an overall zero balance, assuming true concentricity of the shaft to impeller mounting bosses. I wouldn't assume that a turbine manufacturer would have compensating balance marks across the midsection (relieving the compressor to compensate the turbine imbalance for example) which would create a weird moment of inertia, but I could very well be wrong. Granted, I was new and ignorant to turbo philosophy when I did my 60mm upgrade (I just wanted smoke and cheap power at that time ), but I've thrashed it pretty hard and haven't had an issue with it...yet
more boost at about the same spool.
I would really like to see a genuine, quality Super 40/35 for the price of the 60mm upgrade. I would like to have seen it even more back when I did mine because I would have been much more comfortable with a complete 40/35 rather than the 60 H1C...and I probably wouldn't have gone with the PhatShaft 62 I have now
Old Nov 2, 2012 | 04:08 PM
Fox's Avatar
Fox
BAEturbo. complete turbo minus exhaust housing, $495. Bob builds and balances them there. He just does not use Holset housings... he has his own casted. Saves on price where you dont need to spend.
