pros and cons to 4" vs 5" exhaust system
Old Nov 1, 2012 | 08:54 AM
stokes44's Avatar
Default pros and cons to 4" vs 5" exhaust system
were is the best place to by
do I need to change the down pipe
does 4" give more hp
how much hp and mpg can I expect if any?
Thanks for any help
correction does 5" give more hp
Old Nov 7, 2012 | 10:26 AM
tmonroe's Avatar
all 5 does is make it sound deeper ... as for mpg and horses u wont see much mabye a few. your throttle response will be better. i have a 4 and it is all that is needed
Old Nov 7, 2012 | 10:50 AM
RAW's Avatar
RAW
5" is only beneficial over 4" when you exceed about 600HP. Until then, there isn't enough airflow to require the 5".
Old Nov 7, 2012 | 11:40 AM
5" just sounds better
Luke
Old Nov 8, 2012 | 04:06 PM
JBearSVT's Avatar
I would guess the 4" installs easier. Clearance was pretty tight in some spots on the downpipe with mine, I can't imagine how much more of a PITA it would have been if it was 5".
Old Nov 30, 2012 | 02:03 PM
dieselnut73's Avatar
I agree JBearSVT I just put a 4" diamond eye turbo back straight pipe on my truck yesterday and I couldn't imagine trying to get a 5" down pipe in that little bit of room. And my 4" sounds good enough for me!
Old Nov 30, 2012 | 03:38 PM
JBearSVT's Avatar
It sounds a lot better to me since I put the MBRP muffler on. I mean, it really doesn't sound any different in the cab, but outside it was just retarded.
Old Dec 6, 2012 | 02:46 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yep I would have to agree the only difference is sound
Old Dec 6, 2012 | 04:01 PM
H.R.D's Avatar
I have yet to see a company make a 5" downpipe for a 2nd gen truck. Every 5" kit I have installed has a 4" downpipe and then turns into 5" after the downpipe.
Old Dec 6, 2012 | 04:03 PM
JBearSVT's Avatar
Well that would certainly make it easier, there's plenty of room everywhere else.
On the other hand, it sounds like the downpipe would be a bottleneck in a 5" system.
Then again, it's coming off a 3" flange from the turbo, so maybe that's a moot point.
