04.5 engine codes
Old Oct 31, 2012 | 12:33 PM
blacksmoke82's Avatar
Default 04.5 engine codes
i recently put a fass 150 fuel sytem an electric fans on the truck an a smarty. now that i have the smarty i have codes that keep coming up its a low voltage at the lift pump and cooling fan 1 speed an cooling fan 1 curcut code is there any way i can get them to stop showing up? also when they are present i dont get an engine light i get dining an the preheat light comes on an stays on. any help would be great
Old Oct 31, 2012 | 08:15 PM
TheOtherNick's Avatar
The fan ones will always be there since the fan clutch isnt plugged in, i have them on my truck also. I dont get the grid light or a dining so it must be from your Fass system. How did you wire the Fass system in?
Old Nov 1, 2012 | 02:46 AM
we had t into another wire for power cause the truck didnt have the in tank pump. wired just how they said on the fass website. i wanna say it was something like an m11 harness i cant remember
Old Nov 1, 2012 | 12:28 PM
What is the code number for the lift pump code.
Old Nov 1, 2012 | 11:30 PM
p0628
Old Nov 2, 2012 | 12:52 PM
Sounds like the computer is mad that the factory lift pump is not running, id ask the vendor you got the system from if you can jump a wire on the factory harness to make the computer think the pump is running.
burndiesel
10
Feb 7, 2023 01:15 AM
asajay
Sep 10, 2015 12:08 AM
moneypitk5
Feb 12, 2015 11:01 AM
dy19333
Ford Powerstroke 08-10 6.4L
Feb 4, 2015 01:12 PM
24valve4x4
Dec 16, 2014 08:04 PM
