Valve seat falling out @81800miles?
Old Oct 30, 2012 | 01:25 PM
Goingbroke's Avatar
Default Valve seat falling out @81800miles?
I have a 2003 chevy 3500 2wd duramax. injectors replaced @ 41000miles and @ 81700 miles noticed more smoking at idle. Went to the dealer and was told the injectors needed replacing again. I said I was going on a 3000 mile trip and would it be OK? Was told that it would be OK just the fuel economy would go down. 115 miles into the trip the engine lost all the coolant quickly. What had happened was a valve seat had fallen out on #8 cylinder and caused alot of internal damage. A replacement engine required. My question is "can a bad injector cause the valve seat to fall out burn a "V" in the valve and torch the head? Or is it just my bad luck.Anyone with simular experences?
Old Oct 31, 2012 | 12:58 AM
2004LB7's Avatar
doesn't seem likely to me.
i guess that if that cylinder was running hotter or colder then the others then the expansion differences may have caused it to loosen and fall out
sorry for your loss
any photos of the carnage?
Old Oct 31, 2012 | 08:32 AM
Goingbroke's Avatar
Yes I did take photos. Need some computer help to get them on this forum. As soon as i can I will post them. Thanks
Old Oct 31, 2012 | 10:56 AM
Goingbroke's Avatar
Default engine photos
Old Oct 31, 2012 | 11:22 AM
2004LB7's Avatar
ouch, took a chunk out of the valve
a quick google search indicates that there may have been an issue with some of the earlier models loosing valve seats as GM did some revisions to correct this in the newer ones.
Rebuilding The 6.6L Duramax Diesel: Engine Builder
Old Oct 31, 2012 | 03:01 PM
Goingbroke's Avatar
MMM. After talking to GM thay said it was a rare thing w/ a Duramax but since it was a 2003 at only 81000 miles no help from them. I had asked directly if this was an issue with this engine and they said no. I will read what the engind builder has to say. Thanks.
Old Oct 31, 2012 | 05:55 PM
2004LB7's Avatar
it is near the bottom, it is more of hint then hard facts
Old Nov 1, 2012 | 01:43 PM
Goingbroke's Avatar
I read the whole article. Interesting reading. Thanks for the info
Old Nov 1, 2012 | 03:31 PM
2004LB7's Avatar
good history and background info on the duramax
Old Nov 2, 2012 | 08:30 AM
Goingbroke's Avatar
I once had complete faith in this truck, now I will always wonder if I will make it round trip without any "issues". New engine in,driven a few hundred miles and now in storage untill spring 2013,thats when the racing season starts again.
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
