help! 97 f250 4x4 not working and axle prob?
Old Oct 29, 2012 | 12:21 AM
ford man's Avatar
Default help! 97 f250 4x4 not working and axle prob?
i have a 97 f250 4x4 with a zf6 6 spd transmision out of 99 or 00 f350 and new process 271 transfer case manual warn lock outs
in 2wd i feel vibration coming from what seems to be under the back seat but carrier bearing is new and driveshaft has been recently shortened and re balanced
in 4wd high or low range the front wheels pull some then the front end on passenger side pops and it seems like the front wheels quit pulling then they pull again then pops again ect
in other words pull some pop pull some pop
pop represents a dead point in front wheel traction
Old Oct 29, 2012 | 12:23 AM
1999stroker's Avatar
Are your hubs locking? Have they been replaced or rebuilt to your knowledge check and make sure the fluids are full.
Sent from my DROID BIONIC
Old Oct 29, 2012 | 12:29 AM
ford man's Avatar
im not sure if they have been replaced or rebuilt but i do know that three weeks ago the truck was an auto and the 4x4 worked fine i just put a 6sp in it and now it keeps poping and the front diff feels like its slipping when it pops
Old Oct 29, 2012 | 12:32 AM
Oh I see. Yeah I'll have to look into it. Are you sure that you have the right set up with the swap
Old Oct 29, 2012 | 12:36 AM
ford man's Avatar
what do you mean by "right set up" all i knew to do was buy the trans and bolt it all in maybe i did something wrong?
Old Oct 29, 2012 | 12:40 AM
Well I don't know if zf6 matches up to your transfer case or nlt.
Old Oct 29, 2012 | 12:41 AM
ford man's Avatar
i bought the transfer out of the same truck as the tranny it was a package deal
Old Oct 29, 2012 | 12:43 AM
Oh. So its acting like its popping in and out of 4x4?
Old Oct 29, 2012 | 12:45 AM
ford man's Avatar
yes the popping noise is coming from the front passenger side it seems like
Old Oct 29, 2012 | 12:48 AM
Sounds like the hubs bad maybe.is take that hub out and make sure it locks and unlocks freely. Were the hubs locked when you tried to put it in 4x4?
