Running temps.
Old Oct 28, 2012 | 05:16 PM
NewBreed's Avatar
Default Running temps.
I recently bought a 06 Ram 4x4. It has the 5.9. It's the first diesel truck I ever driven. I noticed that the temp gauge is alway moving. It bounces back and forth between 190-200. Is that normal?
Old Oct 28, 2012 | 05:18 PM
TheOtherNick's Avatar
yup.
Old Oct 28, 2012 | 05:28 PM
NewBreed's Avatar
Thanks. I was concerned a little because I'm going on a road trip next week.
Old Oct 28, 2012 | 10:40 PM
Your just seeing the t stat open and close around 190.
Old Nov 1, 2012 | 09:57 AM
steved's Avatar
Replace your thermostat...this is typical of a faulty (but not failed) thermostat...its termed "tick-tocking". It is "normal" to some folks, but it is not actually normal to the Cummins.
From a cold start, it should run up to just above your normal operating temps initially (until the thermostat initially opens), drop slightly below your normal operating temp (inrush of cold coolant from radiator), then settle down at you operating temperature...it should not move much at all afterwards (unless you're towing heavy).
I had an electronic gauge on mine, and could watch the coolant temp; the temperature doesn't fluctuate much at all when the thermostat is operating normally.
Jun 8, 2015 01:40 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
CumminsAtYa
Mar 17, 2015 09:23 AM
carid
Jan 12, 2015 04:32 AM
ssmith.77
Jan 11, 2015 02:03 PM
