2002 duramax fuel gauge
Old Oct 21, 2012 | 01:55 PM
hydromax5's Avatar
Default 2002 duramax fuel gauge
The fuel gauge on my duramax is out and shops want about 800 to fix. Anyone know if there's a quick fix for this or if it's really the part in thank that needs replaced?
Sometimes the needle shows full but most of the time it's on empty.
Old Oct 24, 2012 | 10:17 AM
KS2A's Avatar
do you have a DIC instrument cluster with steering wheel controls? the easy test is to compare the fuel gauge reading to the digital "miles to empty" number. if the gauge shows empty but the truck reads out that you have 200 miles of fuel left then you have a stepper motor failure. every silverado, tahoe and yukon in this body style generation that i've had needed one or more stepper motor replaced in the cluster.
Old Oct 24, 2012 | 01:17 PM
turbostang7's Avatar
02's don't have that
Sent from my DROIDX using Tapatalk 2
Old Oct 27, 2012 | 07:55 AM
hydromax5's Avatar
I don't have the DIC. Would the needle still go up sometimes if it needed replaced?
Old Oct 28, 2012 | 04:39 AM
KS2A's Avatar
if the stepper motor is bad- it will do whatever it wants. can't recall if the low fuel idiot light is triggered with the gauge or with the signal from the sending unit.
Old Nov 27, 2012 | 11:57 AM
fullthrottle23's Avatar
I think there's something up with the gauge in my '01 2500. When going down from full, once it reaches a half a tank it's like you can watch the needle drop. And when filling it up the needle pegs out a bit past the F for full and the truck still takes another 5-6 gallons, sometimes more.
Any suggestions?
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
