05 #5 injector line failure once a year
Old Oct 20, 2012 | 10:26 PM
rvman63's Avatar
Default 05 #5 injector line failure once a year
Had my truck since new, well taken care of, best truck I ever had. Since new the #5 injector line has filed over 7 times. And just did it again today. Used 2 of the old design...FAILED Used 5 of the updated design...FAILED. Does the injector need to be replace? IS there an aftermarket part available any where that is better? Is there a fix for this problem? My son and I are the only people that service this truck in any way. Not a dealer service problem. Any insight to a cure?
Old Oct 22, 2012 | 08:22 AM
dangerous1965's Avatar
The insulator HAS to be tight with no movement! "Rubber clamp that holds it down." Something is being done wrong over and over again! #5 has never been an issue but #4 has. The pulse going thru the line is intense and any movment will cause metal fatigue and failure! Not an injector problem be sure the cross tube is tight also.
Apr 8, 2015 05:10 PM
Jan 22, 2015 11:40 AM
Dec 3, 2014 09:40 AM
Nov 19, 2014 08:10 PM
Oct 28, 2014 12:40 PM
