Lift springs
Old Oct 16, 2012 | 12:21 PM
Diesel firefighter's Avatar
Default Lift springs
Hey guys I need to know where I can buy 2" lift springs for my 2005 F250 so I can level my truck. Thanks
Old Oct 16, 2012 | 01:40 PM
Mdub707's Avatar
Icon sells some. You should ask up in the sponsor section and see if anyone has some available. You can also just do spring spacers. I made my own 2.5" spacers out of billet aluminum, been holding up for over 50k miles.
Old Oct 18, 2012 | 12:11 PM
Where is the sponsor section
Old Oct 18, 2012 | 12:12 PM
Tyler@TWX's Avatar
FormerVendor
you want spring or spacers bro< I can help
Old Oct 18, 2012 | 12:55 PM
I have a 2" leveling kit but there is a 4 1/4 inch difference from front to rear so I need 2 more inches to get the truck leveled out
Old Oct 18, 2012 | 01:22 PM
Tyler@TWX's Avatar
FormerVendor
What? What kind of leveling kit? 4 1/4 is huge difference.Is what you have a spacer?
Old Oct 18, 2012 | 01:35 PM
Yea I have blocks for the front right now that are 2" it's a 2wd truck an yes u know 4 1/4 is a lot but that's what it is
Old Oct 18, 2012 | 01:39 PM
Tyler@TWX's Avatar
FormerVendor
rear is stock?
Just trying to find some options
Old Oct 18, 2012 | 01:40 PM
Mdub707's Avatar
Yeah something doesn't add up there.
A 250 usually has smaller blocks in the rear than the 350. Stock F250 rear blocks are like 2 5/8" tall, and stock 350 blocks are around 4" or a hair under. See what blocks you have in the rear. Usually when doing a standard 2.5" leveling kit up front on a 250, you need to add the 350 blocks to make it level, or the front will sit higher than the rear. Something isn't adding up here.
Also, you should NOT be stacking anything, one block or one spacer only, don't stack two blocks up.
Old Oct 18, 2012 | 01:42 PM
I'm guessing its stock I bought the truck used an haven't done anything other than exhaust egr delete oil cooler heads an arp studs
