NEED HELP!!!
Old Oct 16, 2012 | 12:50 AM
anj1230's Avatar
Default NEED HELP!!!
I have a 2003 Dodge Ram 2500 diesel, it idles fine but when I put it in gear it cuts off. Its an automatic, it seems like it stalls and takes some cranking to get it to start again. Just replaced fuel pump in tank. Don't know what it could be.
Old Oct 16, 2012 | 12:52 AM
1999stroker's Avatar
Did you bleed the fuel system to get all the air out?
Sent from my DROID BIONIC
Old Oct 16, 2012 | 11:17 AM
anj1230's Avatar
yes it runs fine its only when i put it in gear to drive it the truck will just shut off i think it might be the shut off siolynoid geting stuck but i have no idea where it is this is my first diesel and have no idea what to do.
Old Oct 17, 2012 | 08:03 AM
dangerous1965's Avatar
Do you have a TQ lock switch? If not check your grounds!
