Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
06 lly high egt's
Old Oct 14, 2012 | 09:15 PM
anthonyon44s's Avatar
Default 06 lly high egt's
just bought an 06 lly bone stock put in an edge evo tuner egt's would hit 1300 maybe on 4 (100hp) setting and i was in it for a long time, now after driving for abt a week and a half on tune 3 there up there and even with no tune the egt's go to 1300-1400 just tryin to get on e-way and barley getting into it...
just installed k&n filter 2 weeks ago...im wondering if my cat is getting clogged from soot?
truck has almost 200k on it
Old Oct 15, 2012 | 10:54 AM
j johnson's Avatar
that would be my guess..
Old Oct 19, 2012 | 05:10 PM
anyone?
Old Oct 22, 2012 | 06:13 PM
1959JD630's Avatar
Llys are known for having poor air flow to the turbo. Try getting an lbz mouth piece for the turbo or an afe one. That usually solves the air flow which may help lower egts
Old Oct 25, 2012 | 02:52 AM
2004LB7's Avatar
2x
cat could still be on the list too but not as common
Old Oct 26, 2012 | 02:57 PM
BriteWhiteRam's Avatar
Originally Posted by 2004LB7
2x
the mouthpiece on the 2006 LLY is the same as the LBZ, its the same engine, just a different tune, the 04.5-05 LLY's are the ones with the poor induction flow
try cutting out the cat, or a 4" exhaust, my truck with a 415rwhp tune will hit 1400*F if I keep into it hard, but i wouldn't consider that high
If I were you I would ditch that K&N setup, the stock intake is PLENTY of airflow for well over 500hp, the K&N also allows through a lot more dust and contamination than the stock filter setup as well
Old Dec 23, 2012 | 05:19 PM
jevanb's Avatar
put in a aftermarket DP and ditch the cat, I have a PPE modded air box and on EFI`s 150hp tune I see about 1275-1300 for about 1 sec spike, @ 26psi. when I had the factory DP it would be a lot higher on the temps. our turbo is rated for 1375 continuous..
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
robbyS
Apr 16, 2015 02:22 PM
