Cheap Mods On A Stock Truck Thread.
Old Mar 16, 2007 | 08:51 AM
Johnny Cetane's Avatar
Default Cheap Mods On A Stock Truck Thread.
post 'em boys. p/n's and links if you got 'em.
cheap mods on a stock truck-
1-remove the aneroid fuel control housing (AFC) (you will need a chisel or left handed drill bit to remove the break off screw) this device controls pre-boost fuel. this is done under 10psi of boost.
2-slide the fuel plate forward then back it up 1/16th to 1/8th of an inch. (you can play with this until your butt dyno says you got it where it wants it)
3-reinstall AFC and slide it all the way forward. (this is also butt-dyno adjustable. i got my best results with it all the way forward)
4-remove the 8mm plug on the top of the AFC. you'll see a starwheel. cranking this towards the engine makes it go forward. forward = more pre-boost fuel = more smoke.
5- go to NAPA. buy this filter: p/n FIL2790. this is known as a BHAF. remove the stock airbox and put this in it's place. bend up some sheet metal as a heat shield.
well there's a start. i'm a crappy teacher tho. !
Old Mar 16, 2007 | 09:08 AM
oldsmokey97's Avatar
you could also do some wastegate adjusting.
either buy the boost elbow........ or if you wanna go the cheap way, get a small 1/4in. hose clamp and clamp off the hose going from the back of the afc housing to the turbo. This will in result., increase the boost pressure that the turbo will push.
Lance
Old Mar 17, 2007 | 09:48 PM
rbratby's Avatar
you can change the diaphram washer in your afc housing also. you can drill you banjos out bigger also.
Old Mar 17, 2007 | 11:01 PM
Mslaughter's Avatar
Grind down the stock fuel plate.
Old Mar 18, 2007 | 12:45 AM
thought about doin that once before but wasnt sure how much bigger to go w/out causin some kinda leaks.
How much bigger did ya go??
Lance
Old Mar 18, 2007 | 06:49 AM
rbratby's Avatar
i took the washer with me to the hardware store. the washers are the same size. the new one is thinner than the stock one. the one i purchased does not have a lip on it like the stock one does.
Old Mar 18, 2007 | 10:31 AM
Ruckuz's Avatar
Johnny, Nice post! Don't know if you got my messases on Dieselram, but i sent them back, didnt think they were working. I wasn't ignoring you
Old Mar 18, 2007 | 10:36 AM
Ruckuz's Avatar
By the way......
Gauges
Old Mar 18, 2007 | 01:22 PM
na man............. I was talking about the banjos. How much bigger can ya go with em and did it really make a difference???
Lance
Old Mar 18, 2007 | 01:47 PM
rbratby's Avatar
it did make a difference. not sure how much but i did notice a good bit of difference. i cant remember how big i went. i removed the banjo completely now. i have a fitting screwed in there now with a 1/2in fuel line hook to it.
