Rear Door Wiring
Old Sep 18, 2012 | 08:10 AM
paxlaser's Avatar
Default Rear Door Wiring
When I bought my truck the driver's side rear door would not lock and the speaker was inop. I read somewhere that Dodge made the wires to short and this is a common problem. Took the door apart and this is what I found. The broken wires are on the door and not on the cab. I hope this can help someone. I'm not sure if this is the right area to post this but here is a pic. Rear Door Wiring-img_0496.jpg
Old Sep 18, 2012 | 07:45 PM
dmaxkiller's Avatar
had the same problem. i had to cut my boot open and slice the wires and then tap the boot up. its not if it happens its when it happens and it will happen again.
Old Sep 18, 2012 | 10:27 PM
TheOtherNick's Avatar
Yup I fixed 7 broken wires in mine.
Old Dec 10, 2012 | 06:58 PM
paxlaser's Avatar
Your right...it has happened again. Light will not turn on when door is opened. The window and speaker still work so I'm leaving it alone for now
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
Max713
Apr 17, 2015 01:20 AM
