Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
dt466 dying due to fuel issue
Old Sep 17, 2012 | 06:04 PM
rednekroper05's Avatar
Default dt466 dying due to fuel issue
we have a dt466 in a truck here at work and it will run for a little while which is long enough to get up to speed and drive appx. 2 miles then it dies. you can then prime it and it will run for about the same distance/time. we have changed the fuel filters and it still seems to act the same.
Anybody got any tips i'm not really farimilar with these engines. Also this is in a 1980's international 4700 module truck.
Old Sep 18, 2012 | 08:11 PM
nevrenufhp's Avatar
Very common for the rubber hoses around the injector pump to dry rot, and seep air in. Usually it happens after it shuts off.
You can still get them from a local IH dealer, just have the last 8 of the VIN ready.
To test, you can put about 5 pounds of air pressure to the tank, and see if little leaks appear.
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
