Remove and use new programmer?
Old Sep 16, 2012 | 03:42 PM
tasnyder2012's Avatar
Default Remove and use new programmer?
Can I set all the settings back to stock on my 08 cummins with the smarty programmer. Then use a different brand of programmer without any problems?
*After i set them back to stock and remove it, then can i use a differfent programmer without any problems?
Last edited by tasnyder2012; Sep 16, 2012 at 03:42 PM. Reason: Automerged Doublepost
Old Sep 16, 2012 | 04:01 PM
Yes
Luke
Old Sep 16, 2012 | 06:47 PM
biged681985's Avatar
Yes u can, I would only run smarty or h&s
B.E.D.S.
Big Ed's Diesel Service
Old Sep 16, 2012 | 07:07 PM
Ok, cause I am going to take the smarty i have now off and get one that has the dpf/egr delete on it so i can straight pipe it.
Old Sep 16, 2012 | 08:11 PM
chrisparsons's Avatar
i dont mind you telling that statement aint hittin on all cylinders
Old Sep 16, 2012 | 08:23 PM
BIGHORN08's Avatar
Smarty, IMO, is THE tuner for EGR/DPF deletes. If you're referring to using a Smarty on the "S" version, then you would have no problem reloading the software for the "ME" version and then reusing it. It appears you have not done your research and are costly ignorant. DO NOT get rid of your Smarty just because it will not work with the deletes. If you need help reloading software on it, there are plenty of well-educated, diesel savvy people on this forum; probably the most on the internet.
Old Sep 16, 2012 | 08:36 PM
Set your truck to stock and download the ME software for your Smarty.
Luke
Old Sep 17, 2012 | 06:44 PM
Ok, I am sorry I didn't do all my reasearch. But that helps alot and since I will straight pipe it what is the best exhaust I can get to use? Like flo pro or what?
Old Sep 17, 2012 | 06:54 PM
H.R.D's Avatar
This thread can help with the downloading of new software to your smarty.
https://www.dieselbombers.com/5-9l-c...ocedure-2.html
Page 2 Post# 30 has actually videos that may help as well.
