93 chev 6.5 fuel problems
Old Sep 14, 2012 | 03:00 PM
Tigger13's Avatar
Default 93 chev 6.5 fuel problems
I bought a '93 6.5 5 speed a couple of months ago it ran great at first then it fell on it's face, started blowing white smoke ( unspent fuel) hard starting and overheating fuel pumps. I've replaced the fuel pump, injection pump, and the oil pressure switch now I have a bunch of new parts with the same problem, please help thanks
Old Sep 14, 2012 | 03:25 PM
Mayhem's Avatar
Does the waste gate move freely while not running should be able to move by hand??
Old Sep 14, 2012 | 10:18 PM
Tigger13's Avatar
Yes it does with the pressure of the spring
Old Sep 15, 2012 | 05:29 AM
Mayhem's Avatar
can you do a compression test and post results?
Old Sep 15, 2012 | 08:25 AM
ebarresi5894's Avatar
The white smoke could be head gasket issues a well
Old Sep 15, 2012 | 08:51 AM
Tigger13's Avatar
White smoke smells like fuel, if it was a head gasket what would explain the overheating fuel pumps
Old Sep 15, 2012 | 09:21 AM
Mayhem's Avatar
By fuel pump are you meaning lift pump or injection pump or both ????????????????
Old Sep 15, 2012 | 09:57 AM
Tigger13's Avatar
The lift pump on the frame rail
Old Sep 15, 2012 | 11:53 AM
Mayhem's Avatar
The LP overheating issue could be one of 2 things wrong with it 1st ic could be that the fuel sock in the tank is clogged or caked up with debris or you are experencing an electrical issue of some sorts,the white smoke means you are not burning all the fuel entering the cumbustion chamber-chambers either bad piston ring or rings or a cracked I would do is a cmpresion test make sure all cylinders are within plus or minus 10%
HardLuck
Jun 24, 2015 08:04 AM
penley`
Jun 7, 2015 04:38 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
