Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
John Deere SE502167 turbo info
Old Sep 9, 2012 | 06:09 PM
cul8r's Avatar
Default John Deere SE502167 turbo info
I just aquired a brand new turbo part number SE502167 from a john deere diesel not sure what size of engine but the castings on the turbo are Garrett Turbo ar 60 m24 1.15 ar on it with a t4 flange. I took housings off to measure turbine size and found on the compressor side it was exducer 70mm inducer 47 and the exhaust side exducer 62mm and inducer 71mm approx measurements with my cheap calipers would this make a good addition to my super b turbo for a compound setup? Any info is appreciated
Old Sep 9, 2012 | 06:19 PM
RAW's Avatar
RAW
That turbo is used on OEM 6.8L Deere engines, and 110hp to 175hp JD tractors. It wouldn't do a good job with compounds, too small. Maybe on a 3.9L Cummins.
Old Sep 11, 2012 | 12:39 PM
cul8r's Avatar
what would you recommend to be a good match to my bd super b turbo on my 2001 ctd?
Old Sep 11, 2012 | 12:41 PM
RAW's Avatar
RAW
Something like a S475. A BIG turbo!
Old Sep 11, 2012 | 03:09 PM
cul8r's Avatar
thats what i was thinking if yer gonna be a bear be a grizzly!
Old Sep 11, 2012 | 03:13 PM
RAW's Avatar
RAW
I have a S471 under my HX35/40. Top turbo isn't anything great, but the price was right. You, having the better and a bit bigger top turbo, need a bigger bottom turbo.
avatardvr
18
Aug 8, 2019 12:38 AM
klein444
Feb 27, 2015 01:53 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
